February 06, 2026, 03:01:48 PM
Rear splines
Topic: Rear splines (Read 1387 times)
Mrbig1
Rear splines
March 28, 2013, 07:16:33 PM »
Can you over lubrcate them? I mean adding enough molly grease to coat eeverything. The manual calls for amounts in grams. Is a liberal coating good enough?
Re: Rear splines
March 28, 2013, 07:27:06 PM »
I doubt anybody measures to the gram. If you overlube them, the rear drive unit will spit grease out the O rings. It'll show up on the wheel and drive unit. Just wipe it off and don't use so much next time the wheel is off. BTW: Use Bel Ray waterproof grease. The Honda paste doesn't last. BR Grease is readily found in auto stores.
Oklahoma_Valk
Central OK
Re: Rear splines
March 28, 2013, 09:27:01 PM »
I like the Bel Ray assembly lube for the rear splines. Regular grease for the shaft and pinion cup.
Let those who ride decide.
NITRO
Eau Claire, WI
Re: Rear splines
March 29, 2013, 09:14:36 AM »
I once had so much grease around the flange that it couldn't seat quite all the way. I had to remove some before I could get everything back together.
When in doubt, ride.
Re: Rear splines
March 29, 2013, 10:17:04 AM »
I use valvoline moly and if I put to much on I know it after the 1st ride. All over my rim.
