November 25, 2025, 07:34:29 PM *
Author Topic: Nutcage/carraige bolt mod question  (Read 994 times)
wiggydotcom
Yorkville, Illinois
« on: April 02, 2013, 12:06:27 PM »
For those that switched to carraige bolts for the rear fender, did you do anything with the carriage bolt square shoulder-like grind it to the same diameter as the bolt? Or did you just let the shoulder be the stop against the fender.  Or does the square fit inside the fender hole?
Thanks.
VRCC #10177
VRCCDS #239
« Reply #1 on: April 02, 2013, 12:30:54 PM »
Those little shoulders under the cap are there for the bolt to dig into and hold while being tightened.
They were originally designed for wood, but they will work on just about anything.
I'd say it is optional to grind them down.
Try one before ya grind on it to see if it sets correctly, if it does then forget the grinding.
I never ground mine.   Now that MGM is a Trike, it don't matter as the fender is all intact in the back garage.
wiggydotcom
Yorkville, Illinois
« Reply #2 on: April 02, 2013, 01:24:48 PM »
Thanks, RJ... Yeah, I was aware of the purpose of the square shoulder and for that reason, I didnt want to crack the fender if the hole was smaller than the shoulder. Once I get the carraige bolts home, I guess I'll know if I need to grjnd or not. Appreciate your help.
VRCC #10177
VRCCDS #239
« Reply #3 on: April 02, 2013, 01:26:11 PM »
What R J said. My carriage bolts have that square intact on the bolt. Appears to be doin just fine.  cooldude  RIDE SAFE.
NITRO
Eau Claire, WI
« Reply #4 on: April 02, 2013, 04:05:39 PM »
Me three.
When in doubt, ride.
wiggydotcom
Yorkville, Illinois
« Reply #5 on: April 02, 2013, 07:45:28 PM »
Thanks all, appreciate your input. I don't know why I keep thinking the rear fender is fiberglass, hence my fear of cracking it. Now that I've again removed it and seeing it's metal, I can see why you left the shoulder bolts intact. I did run mine around the bench grinder just a couple times to knock the corners off the shoulder. The carriage bolts then went into the holes nicely and bottomed
against the heads of the bolts.
My car tire install is almost complete. Yokohama Avid Envigor 205/60R-16. Doing an Interstate with bag rails, etc sure takes a lot longer than Daniel Meyer's tech sessions--and that's with the quick drop kit.
« Last Edit: April 03, 2013, 04:24:06 AM by wiggydotcom » Logged
VRCC #10177
VRCCDS #239
Westsider
Fort Worth TX.
« Reply #6 on: April 03, 2013, 07:03:15 AM »
I've ran two different ct,s on my 01 interstate , and neither one has rubbed  with the shocks  at full bottom out... The first was a faulken, I didn't like it and now its some brand x I found, 205_60 with no mods or rubbing issue's...
Its a Duro 3000 runs great , I like it.... Grin
« Last Edit: April 03, 2013, 02:39:20 PM by Westsider » Logged
wiggydotcom
Yorkville, Illinois
« Reply #7 on: April 03, 2013, 09:18:33 AM »
That's good to know, thanks. I figured the mod was easy enough and it's done so no worries. Take care.
VRCC #10177
VRCCDS #239
