November 25, 2025, 07:24:06 PM *
Author Topic: Bleeding brakes... what am I doing wrong?  (Read 1542 times)
Tropic traveler
Silver Springs, Florida
« on: April 02, 2013, 07:51:12 PM »
This is on the wife's Shadow.
I emptied the caliper, master cylinder, & line out as there was nasty fluid in it. Pushed the pistons back into the caliper then reassembled the whole thing, filled it with fresh fluid & proceeded to bleed the system. Bled & bled for about 20 minues, dozens of times & nothing. I've bled many bike brakes before & never had this problem. Very simple single caliper system on this bike. Every time I pump it up I get a little dribble out of the bleeder but no resistance or pressure from the handle.
What am I doing wrong? I've never had to use a vacuum pump before.
'13 F6B red for Kim
James III
Tampa, Florida
« Reply #1 on: April 02, 2013, 09:06:31 PM »
Did you re-bleed the master cylinder after cleaning out all the old fluid?
James
« Reply #2 on: April 03, 2013, 03:50:05 AM »
Whenever I drain the whole system, I hook a big syringe
to the bleed screw and "prime" the system by pulling
some fluid down from the master cylinder... then pumping
works like normal...
« Reply #3 on: April 03, 2013, 04:31:09 AM »
Lets just make sure you're covering the basics. Fill system, close bleeder, pump, hold lever, open bleeder, close bleeder, release lever, pump, keep repeating.
9Ball
« Reply #4 on: April 03, 2013, 05:54:04 AM »
Typical of air in the system.
I use a syringe and surgical tubing and force fresh brake fluid up through the bleeder to the master cylinder.  Just make sure there is room in the reservoir so you don't overflow it.
It's easier to force bubbles up than it is to force them down through the system.  Your "stuck" air bubble is most likely at the banjo fitting on the master cylinder.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #5 on: April 03, 2013, 01:12:23 PM »
+1 on the banjo fitting. Had that problem once and had to loosen the banjo fitting in order to "burp" that bubble. Bled just fine after that.
Tropic traveler
« Reply #6 on: April 03, 2013, 05:26:01 PM »
I'm such a dork sometimes  uglystupid2.
Went back out to the garage & took off the m/cyl cap, cracked open the banjo fitting at the caliper & let it drip down until about half the fluid was gone from the m/cyl. Proceded to bleed as normal.... some times I wonder about myself.  Roll Eyes Shocked crazy2
Running & almost done!
« Last Edit: April 03, 2013, 05:35:15 PM by Tropic traveler » Logged
'13 F6B red for Kim
Kunkies
Charlotte, NC
« Reply #7 on: April 03, 2013, 07:02:51 PM »
Wow, now that's a nice looking Shadow!  Just had to say it
Tropic traveler
« Reply #8 on: April 03, 2013, 07:16:48 PM »
Should have seen it 6 weeks ago.
Down & out!   :'(
Newspaper pic.
'13 F6B red for Kim
« Reply #9 on: April 04, 2013, 04:50:13 AM »
No biggie, as long as its fixed. We all have our 'moments'.
