February 06, 2026, 05:03:38 PM *
Author Topic: manifold intakes  (Read 1830 times)
zoltan57
Denver, Colorado
« on: April 03, 2013, 03:24:10 PM »
hi,
recently I have been seeing some dark fluid seeping out at the base of the manifold intakes. I have one on each side showing this. has anyone had this happen? if so how much does it cost to have it all six O-rings replaced.  I just recently called several dealers in the Albany n.y. area which I m getting a big difference in pricing.. I been in Colorado for the past 20 years and my mechanic at Aurora Honda who has worked on my bike for the past 12 years ,the only guy I trust told me it is not a big job and labor is around $100.00 and $40.00 for the 6 O-rings.. I am also looking for any fellow Valkyrie riders in the Albany n.y capital district as well to ride with as well with questions regarding Valkyries... my email is emrikhoenig@aol.com if you like to answer there. thanks,
emrik
« Reply #1 on: April 03, 2013, 04:04:39 PM »
It's not hard, just unbolt and slide it out, put in new o ring and slide it back in, do not have to disturb the carberators at all.  Just loosen the clamps and pop the riser out of the rubber.  Hoser   cooldude
mmurffy03
03 standard
toms river new jersey
« Reply #2 on: April 03, 2013, 04:06:01 PM »
a Phillips screwdriver and a 8 mm wrench and 6 o rings very simple
Denny47
#34898
Grove, Ok.
« Reply #3 on: April 03, 2013, 04:47:32 PM »
I just replaced my intake O-rings, picked them up at Honda dealer, $31 and change. Might have gotten them cheaper elsewhere but didn't want to wait on shipping. Not hard to change. Just use a light coating of dielectric grease on them which aids in getting them to slide back into place and also helps them seal. Just snug the bolts up, not too tight.
USAF 66-70, F-105 AWCS
Farther
Quimper Peninsula, WA
« Reply #4 on: April 03, 2013, 04:57:07 PM »
Here you go: http://redeye.ecrater.com/p/2064055/intake-o-ring-kit-viton-gf
~Farther
« Reply #5 on: April 03, 2013, 05:05:26 PM »
+1 A very easy job. Less than $13 for the O-rings from redeye. Retighten the bolts not to exceed 7ft-lbs or 84 inch-lbs. Go for it!  Cool
My rides:
« Reply #6 on: April 03, 2013, 05:13:27 PM »
Red eye is our sponsor but if time is important, find a local hydraulic supply house near you. Get a #123 O ring in Viton or Silicone. Here in AZ they're about .60 each. Loosen the upper hose clamp and remove the 8 mm bolts at the base. GENTLY pull out the base of the tube. Don't YANK as 3 of the tubes have a vacuum tube attached to them. From there, the replace is simple.
97Valk_CT_Euless
Euless Tx
« Reply #7 on: April 05, 2013, 06:50:07 AM »
I used a piece of transparency film between the intake and the head after removing the bolts when sliding them in/out to protect both surfaces. Made me feel better anyway. Can be alittle tight getting them out.
AZdougness
« Reply #8 on: April 05, 2013, 12:12:21 PM »
If you take all of the manifolds bolts out the carb rack can be pushed up easy enough to allow the manifolds to come out without any threat of scraping.
« Reply #9 on: April 05, 2013, 04:05:11 PM »
hi,
emrik
$40 for six 0-rings.  Thats hilarious (oooops) I mean that just gives me a pain I cannot locate.  I bought 50 of them viton 0-rings for $10.  after I used 6, I packaged the rest in 6 packs and sent them out to VRCC members that needed them.  $40 you have got to be kidding me.  And $100 to replace them, ya thats a deal...a deal for someone that has more dollars than sense.
Wow, just think how much money we would all spend if we had 0-rings, spark plugs, oil, coolant, cables, valve adjustments, final drive grease, battery changes and timing belts all done by a dealer that would charge $140 to switch out 6 little 0-rings
valku2
« Reply #10 on: April 08, 2013, 05:00:15 PM »
I stopped in the local hyrdaulic hose supply store after work tonight for some O-rings.  Is the #123 O-ring correct?  Clerk/owner thought maybe an 8123 was correct?  TIA.
1999 Pearl Orange/Black Valk Std. (currently in tourer mode) SOLD IT
2004 CBC Rune - bone stock - SOLD IT
2014 Red, Yellow and Black Honda GROM - stock
2018 Electric Blue HD Softail Deluxe
Brian
Monroe, NC
« Reply #11 on: April 08, 2013, 05:34:49 PM »
The wrench to fit these intake bolts should be in the tool kit on the bike. They sure don't need to be super tight. If you remove all the intake bolts at the same time the carbs should be able to be lifted high enough to replace the O-rings without removing the intake tube itself. If you do remove them I found that a light coating of silicone die-electric grease at the lip of the boot really helps to make them slide in place easier. A few small spots of black Permatex will help hold the o-ring in its channel. They do fall out if you are not careful. This task is very easy and does not need to been done by the dealer.
« Reply #12 on: April 08, 2013, 06:07:29 PM »
The #8123 might be a brand equivalent number. Did you take the old O ring with you? Also get the viton material.
valku2
« Reply #13 on: April 09, 2013, 05:13:09 PM »
I'll try and take one in on Friday.  Thanks Sandy.
97Valk_CT_Euless
Euless Tx
« Reply #14 on: April 10, 2013, 05:47:42 AM »
Doh! I wish I'd thought of that. Feel pretty stupid doing them one at a time.
