November 25, 2025, 07:23:53 PM
Red or blue Loc Tite?
Topic: Red or blue Loc Tite? (Read 967 times)
ragincajun
Atascocita, TX
April 04, 2013, 07:44:02 AM »
Which to use for normal pieces like radiator cover?
VRCC Member #34758
Re: Red or blue Loc Tite?
April 04, 2013, 07:55:24 AM »
If you ever want it to come off again, blue. And a little goes a long way.
ricoman
Sarasota, FL
April 04, 2013, 07:58:34 AM »
Quote from: Valkorado on April 04, 2013, 07:55:24 AM
+1,
leave the red tube at the store
Thrud
2000 Valkyrie Interstate
April 04, 2013, 09:12:03 AM »
You should also know that thread anti-seize compound is recommended with any fasteners used in high temperature areas, such as the engine manifolds, exhaust, etc.
April 04, 2013, 09:17:30 AM »
Yep, thread locker is a no no.
Anti-seize is recommended.
April 04, 2013, 04:22:57 PM »
As stated.....
Red Loc Tite if you never want to take it back off again.
Blue Loc Tite if you plan to take the screw/bolt back off at some point.
And again......anti-sieze on high temp items.....so your fastners won't seize into whatever they've been threaded into..
wiggydotcom
Yorkville, Illinois
Reply #6 on:
April 04, 2013, 06:50:27 PM »
To further clarify things in general...
Blue is for medium strength holding power.
Purple is for small fasteners.
Red isn't necessarily permanent, but probably requires heating(like with a torch) to release the grip
on the fastener.
VRCC #10177
VRCCDS #239
=> InZane XXV
