February 06, 2026, 06:55:20 PM
Won't start
Topic: Won't start (Read 1253 times)
HammerHead
Won't start
April 09, 2013, 08:34:15 AM »
I installed a new battery and now nothing when I push the starter button. Lights go on and dim when I push the starter button but no response from the starter. Checked cables. Positive terminal has battery cable plus blue wire. Negative has battery cable plus yellow wires. Am I forgetting something? Also, can't get the green neutral light to engage now. I'm stumped as everything was working good before replacing the old battery. Checked all of the fuses.
Re: Won't start
April 09, 2013, 08:41:40 AM »
Probably the first thing would be to check the battery is installed properly. Correct pole to correct pole.
Checking the kill switch and starting button would be a good place to start.
Then I'd take all the extra wires away from the battery and try that.
The headlights should go
OUT
, not dim. If they only dim, you have a connectivity issue.
Re: Won't start
April 09, 2013, 04:59:43 PM »
New batteries need to be charged up with a trickle or smart charger before installing in the bike. Just because it's new doesn't mean it's fully charged. I have a feeling you need to do the starter button maintenance. Find it in Shop Talk section on the website.
HammerHead
Re: Won't start
April 09, 2013, 05:03:49 PM »
Figured it out. Kickstand safety switch was the problem.
shortleg
maryland
Re: Won't start
April 11, 2013, 06:04:03 PM »
Don,t you feel better that you fixed it.
Shortleg[Dave]
Chiefy
Sarasota, Florida
Re: Won't start
April 12, 2013, 04:58:43 AM »
Quote from: HammerHead on April 09, 2013, 05:03:49 PM
