February 06, 2026, 06:57:02 PM
Rear Gear Ratio
Topic: Rear Gear Ratio (Read 1071 times)
BIG Bopper
Rolling Thunder 2017
Palm Springs, CA
Rear Gear Ratio
April 10, 2013, 11:29:35 PM »
I have read posts pointing to the use of Goldwing final drive units being used. Does this change the gear ratio? What results are seen in RPM at highway speeds and fuel mileage?
Tim "Big Bopper" Bannister
Owner
Celebrity Tours
Palm Springs, CA
Re: Rear Gear Ratio
April 11, 2013, 04:06:22 AM »
same ratio. only parts are being used, a GW FDU cannot be used on a valkyrie due to bolt up differences.
only ways to lower RPMs are with a larger car tire or the later 97-00 GWs 4th and 5th gears.
I've posted the ratios before, a search should bring them up.
