February 06, 2026, 06:55:51 PM *
Author Topic: Drive shaft grease????  (Read 1535 times)
JerryH
« on: April 11, 2013, 06:25:05 AM »
Carquest - this is listed as a Moly Disulfide grease with graphite.  Will this work on the drive shaft??
http://www.carquest.com/webapp/wcs/stores/servlet/product_CARQUEST+Fluids%2FOils%2FGreases+Industrial+Moly+EP+Grease+-+Multi-Purpose+long+lasting+in+wheel+bearings+and+chassis%2C+16+oz+can%2C+s__10151_-1_10651_1444733_?acesApp=0
Copy and paste to see the site page.
TIa
Jerry
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: April 11, 2013, 11:46:07 AM »
Guard Dog Moly Lubricants (VRCC sponsor) makes a product that can be used for the entire drive line lubrication needs: Guard Dog 525 Moly grease. Always replace the three O-rings to ensure that the grease stays put.
The drive unit also needs to be drained and properly refilled with a good quality lubricant/dope.
I prefer a synthetic rather than a petroleum based dope.
« Last Edit: April 12, 2013, 05:52:16 AM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: April 11, 2013, 05:19:59 PM »
Your link didn't work for me. If the grease is waterproof and has moly in it, it should be good for all the drive line needs. Some of us get pretty fussy about the wheel splines. The Guard Dog is great stuff but I think it has to be mail ordered. Bel Ray Grease is available everywhere. On the drive shaft I use valvoline Durablend grease with moly. Don't use Hondas moly paste unless you mix it with some waterproof grease.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #3 on: April 11, 2013, 05:48:58 PM »
I removed my shaft after 75,000+ miles. It looked like show room except for the crud on the end that was easily wiped off.  I removed the old stuff and put some Molly paste on it. I think the seals are most important instead of which grease to use.
