January 28, 2026, 11:03:44 PM *
Author Topic: How to add cig lighter to run extras  (Read 2417 times)
rwoulf
« on: June 27, 2009, 12:17:33 PM »
Can anybody help me add cigarette lighter to valkyrie IS so I can recharge cell phone and run GPS off of it with out blowing fuses on bike or accessories?
Can electrically challange person do this?
JimL
Naples,FL
« Reply #1 on: June 27, 2009, 02:30:23 PM »
You should be able to find what you need here:
http://www.easternbeaver.com/Main/Products/Socket_Kits/socket_kits.html
Thunderbolt
Worthington Springs FL.
« Reply #2 on: June 27, 2009, 06:18:22 PM »
maybe someone that lives close to you could give you a hand.  What most people do is use the accessory fuse which comes on with the key to activate a relay which feeds an auxilliary fuse panel and feed the extra lighter sockets,lights,horns from that fuse panel.
stude31
Topeka,ks
« Reply #3 on: June 28, 2009, 12:01:14 PM »
Jim!!   Love the link... are those the standard connections for our "honda" motorcycle or is that for the "bmw"?   I am thinking of putting one on my bike.... what would you suggest or have you put one on before?  I was thinking of the fairing socket looks like a good spot to mount one and it will be camo'd pretty good there too....
« Reply #4 on: June 28, 2009, 02:49:15 PM »
Conceptually:
Relays demystified (from www.rattlebars.com):
JimL
Naples,FL
« Reply #5 on: June 28, 2009, 03:10:55 PM »
Hey Joe, yes I ordered the "Cigar Socket Kit" and I did install it on my fairing (right side).  It works great, however be sure to order the "fused 60 inch lead" (I ordered one that was too short and had to add some wire).
Jim
PAVALKER
Pittsburgh, Pa
« Reply #6 on: June 30, 2009, 02:28:38 PM »
I installed a few waterproof power outlets on my I/S that I got at WalMart or local PepBoys. One out from under the rear seat so the pass could use it, or I could put my cell phone, camera or whatever in the trunk and charge it from the power port.  The other one I zip tied to the handlebars, under the riser cap (you can't see the zip ties) so I could plug in my Garmin GPS or portable CB and remove it easily enough.  I connected them directly to the battery, ran a pig tail off the battery and connected both to them using wirenuts and tape.  Run the wires out of the way and I did install one in line fuse for both.  All has worked well for 2 years.   Did similar installs on my VTX.
John
Madmike
Campbell River BC, Canada
« Reply #7 on: June 30, 2009, 03:39:08 PM »
http://www.cyclegadgets.com/Products/product.asp?Item=MS-MAJ
http://www.solarseller.com/low_voltage_dc_pumps__lvm__teel__accessories__plugs_and_extensions.htm
Here are links to a couple of vendors that offer some interesting stuff.....
