February 06, 2026, 06:57:01 PM *
Pages: 1 [2]   Go Down
Author Topic: OEM valve stem question  (Read 7138 times)
amazngrace
Eastern Shore, Virginia
« Reply #40 on: April 17, 2013, 05:47:26 PM »
Just found my front stock stem leaking last week, and replaced with Kurveygirl 3/4" straight
stem. Had to take the wheel off to break the bead as I didn't have a wide enough clamp.
It sealed up nicely,  and stem access is good on the front.
...ED
99 Red and Black IS
Brian
Monroe, NC
« Reply #41 on: April 17, 2013, 06:14:45 PM »
I sure like that spark plug pump. I hate to admit it but I always wondered if these pumped gas vapors into your tires and why would anyone do that?
I believe the c-clamp I use for front brake work on the cars is an 8 inch, if not I will get one this week. I plan to call Jake Wilson tomorrow to order the valves stems. I agree that I would like to have the nuts exposed. I had this type years ago on a Yamaha Virago and never had any issues.
I still can't believe that I overlooked not replacing that rear stem last year when the tire was replaced.
We have a local poker run this Saturday for charity and plan to take it easy till I get the new stems.
Thanks everyone.
Daniel Meyer
The State of confusion.
« Reply #42 on: April 17, 2013, 07:28:36 PM »
I've used one, and they will seat a tire bead effectively...done it beside the road. Still carry an electric pump for more convenient use in "less dramatic" situations than a complete unseating.
And just to confirm...they have their own fresh air intake to suck fresh air into the cylinder...seems to work...anyway, output air is safe...I've played.
CUAgain,
Daniel Meyer
« Reply #43 on: April 18, 2013, 03:06:47 AM »
On this day, we struggled with a couple of 6-inch clamps that Joe bought
at a nearby Sears...
It is hard to get two boards and a Valkyrie tire in the jaws of a 6-inch clamp,
and leaving out the boards puts such a point load on on the tire it makes
you think you're going to punch a hole in the sidewall before the bead
pops off... 6-inch clamps are usually the biggest you can find at Lowes
or Sears or ... I ordered the 8-inch clamp from Amazon...
Hotrodwing
Clarks Summit PA
« Reply #44 on: April 18, 2013, 03:37:50 AM »
I use the stock stems with a tip i got from the goldwing riders.  You put a small zip tie between the stem and the holder to hold it in place.  Never had an issue, but I also change my stems every tire change. Just cheap insurance.  Just changed my front tire with 19000 miles on it.   Avon Cobra and i run Ride on in my tires and run 40 psi.   Ps   I also carry a few metal stems with me at all times just in case.   cooldude
« Reply #45 on: April 18, 2013, 03:40:11 AM »
I bet what you are doing will keep you trouble free. But cheap? Don't OEM stems cost $20 a pop?
Brian
Monroe, NC
« Reply #46 on: April 18, 2013, 06:21:49 PM »
The dealer that mounted my new tire charged me $12 extra for the OEM stem and $15 for the tire work and balancing.
« Reply #47 on: April 18, 2013, 06:47:24 PM »
Not to shabby for cost overall. I usually get a tire mounted and balanced for $20.
My rides:
pancho
Bonanza Arkansas
« Reply #48 on: April 19, 2013, 03:56:49 AM »
Dang it!!!!  Now I have one more thing to check out!!!
Do you really carry around that C clamp and two boards Mike??
Yep... I've been on two rides where people's OEM valve stems failed, and a couple of
other rides where there were flats...
I have the clamp and two boards in my saddlebags, a spark-plug pump (supposedly they
can spew out enough air to rebead a tire) and some tire plugs. And Ride-on in my tires.
Here's the spark-plug pump:
http://www.aerostich.com/tools/tire-repair/pumps-air-compressors/engineair-power-pump.html
I've got two good valve stems in my tool box... I need to remember to throw them in the
saddlebag too...
A flat tire shouldn't be a show stopper...
-Mike "well..."
You da man Mike........
Pages: 1 [2]   Go Up
