February 06, 2026, 06:55:48 PM
Sealant for Cam Cover to bolt?
Topic: Sealant for Cam Cover to bolt? (Read 1134 times)
JerryH
April 17, 2013, 12:14:29 PM »
A search on sealant recommended either "water pump gasket" sealant or "silicon" sealant to use on the cam cover upper bolt.
Any recommendations on either one? How much to use?
TIA
Jerry
F6BANGER
Albuquerque NM
Re: Sealant for Cam Cover to bolt?
April 17, 2013, 12:21:57 PM »
Never used sealer for the cam cover.....there shouldnt be any oil there anyways.....
97Valk_CT_Euless
Euless Tx
April 17, 2013, 12:26:15 PM »
No sealer On mine
April 17, 2013, 01:38:10 PM »
Do you mean the timing belt cover?
JerryH
April 17, 2013, 04:18:45 PM »
yes - my mistake. lets try this again.
TIMIING COVER, UPPER RIGHT bolt----sealant??? Type?? Amount??
TIA - again
Jerry
April 17, 2013, 04:32:52 PM »
I have no sealant on the Oring for my timing cover.
My rides:
Reply #6 on:
April 17, 2013, 04:37:40 PM »
That bolt goes into the oil galley in the engine no pressure but oil weepage might happen. Use a light coat of permatex gasket sealer. If you don't have that, waterpump gasket sealer will also work. Remember, it's not under pressure.
JerryH
Reply #7 on:
April 17, 2013, 04:41:44 PM »
got it --thanks
Jerry
