February 06, 2026, 06:43:33 PM *
Author Topic: Front fork seal info needed  (Read 1174 times)
longrider
Vernon, B.C. Canada
« on: April 22, 2013, 07:26:21 PM »
For you gurus.       Sometime ago i think I remember that the VTX 18R and Valk take the same seals.  Valk part no is 51490 MWO 003,
 VTX is 51490 MCA 003.  Are they the same?  I've got a set here for wifes the 18R and may need to use them on the Valk if they will fit.
Warren
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
« Reply #1 on: April 23, 2013, 12:14:42 PM »
Warren,  I can't answer the question if they are the same or not.  But if you have a leaking fork seal, I would definately try the "film trick" or the Sealmate.  I've done the "film trick" twice over the years and it has worked both times.  It's worth a try and way easier than replacing the seals.  Gary
« Reply #2 on: April 24, 2013, 05:36:40 PM »
All the seals are the same. Even 1800 Wings take the same units. The wings have had a seal problem (premature failure). In '06 a new stronger seal was developed. It should fit the Valks and VTXs. My wing has had 2 fork rebuilds in 53K. The Valk has had one (2 sides) and I just did the right side again at 134K.
« Last Edit: April 24, 2013, 06:14:25 PM by sandy » Logged
longrider
Vernon, B.C. Canada
« Reply #3 on: April 25, 2013, 06:51:45 AM »
Thanks Sandy.  I was sure I read that on here or the VTX site a few years ago.
