BWANAVALK
« on: April 25, 2013, 01:27:03 PM » |
Trying to replace pads and I can't get the sloted set screw out. Tried , big screw driver,impact driver. Don't want to drill or easyout unless----. Rear comes out easy, don't need rear pads, need front pads.
Any suggestions?
Bwana
« Reply #1 on: April 25, 2013, 01:35:33 PM » |
Heat gun.
quexpress
« Reply #2 on: April 25, 2013, 03:42:37 PM » |
I still have a full deck. I just shuffle slower ...
« Reply #3 on: April 25, 2013, 03:50:59 PM » |
Any suggestions?
Bwana
did you remove the calipers first or try to remove the "set screw" If you removed the calipers, put them back on its much easier on the bike
« Reply #4 on: April 25, 2013, 04:43:43 PM » |
Impact driver didn't work !? Hmm, add some heat and try it again. Then never-seize will help after that.
« Reply #5 on: April 26, 2013, 10:56:19 AM » |
Probably too late, but a good fitting screw driver is the most important part.
I bought a good screw driver and dedicated it for those screws only.
It has a square shank so I can use a small crescent wrench on it.
Big thing is to not tighten them when placing them back.
Snug does it best.
Dr Bobs Patient
« Reply #6 on: April 26, 2013, 11:39:26 AM » |
I had the same problem. Couldn't even get them with a drill and easy out (broke the easyout!). I wrapped a wet rag around the caliper to absorb the heat coming too far up the unit, heated the body of the caliper with a small torch (one step up from a BIC lighter) around were they screwed in, then attached a vise grip to the shaft. It eventually came loose. Replaced them with new bolts and some antiseize!
I keep doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
Tropic traveler
Silver Springs, Florida
« Reply #7 on: April 26, 2013, 06:32:32 PM » |
Had to weld a nut onto the boogered up set screw to get it out one time. Got a nut with an i.d. roughly the same size as the screw then used my MIG to weld it onto the set screw. Held the nut with the ground clamp to make proper ground. Probably was the heat of the weld as much as the extra turning power of the nut that got it out.  New stock set screw with a generous coating of anti-sieze for the reassembly.
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
« Reply #8 on: April 27, 2013, 05:19:54 AM » |
Haven't heard back, so he must not be to interested.
« Reply #9 on: April 28, 2013, 10:41:39 AM » |
B.A.T.
BWANAVALK
« Reply #10 on: April 29, 2013, 07:47:12 AM » |
Thanks for the help. I'll try the heat gun w/rag this weekend.
