February 06, 2026, 06:38:57 PM
Engine coolant temp. sensor?
Topic: Engine coolant temp. sensor? (Read 1677 times)
jammer
#5407 3 valks 97-98-99
Illinois
April 27, 2013, 04:34:43 PM »
Does this thing go bad? How would U test it?
My buddies temp light is coming on.
98 Tourer, lots of miles. Bike has new thermostat & is not over heating
G
Re: Engine coolant temp. sensor?
April 27, 2013, 08:21:11 PM »
My 98 tourer hot light has been fluttering for years now. Someday I'll pull the tank and replace the sensor.
April 27, 2013, 09:11:43 PM »
Replace the switch and see if the light behaves itself.
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
April 28, 2013, 07:58:45 AM »
Quote from: sandy on April 27, 2013, 08:21:11 PM
My 98 standard has been doing the same thing. I installed gauges and have continued to ignore the light for years now. There is an upgrade/repair in shop talk that I fully intend to do one of these days.
Misfit
Colorado Springs Colorado
April 28, 2013, 08:12:48 AM »
It is not your temp sensor that is bad. It is your indicator unit. Part #38710-MZO-003 $45.24 through HDL. It is located behind the left side cover. Pull the cover and remove the coolant overflow bottle. It will be located right behind the bottle towards the front of the bike. Remove the two wire connectors and plug in the new. Takes less than 5 minutes.
April 28, 2013, 08:17:31 AM »
Misfit, ya'll right on target good buddy. I'd forgotten about replacing mine a few years ago till you menioned that.
Chased that damn problem for a couple of months, found it and replaced the unit.
Chillerman
Golden, CO
Reply #6 on:
April 28, 2013, 08:45:35 AM »
The 99's and earlier used a thermosensor and an ECT indicator unit that Misfit was talking about. 2000 and later used a thermostatic switch. I changed my sensor out to a switch years ago and changed some wiring. There is a write up on it somewhere but I forget.
Reply #7 on:
April 28, 2013, 08:56:47 AM »
When does the temp lite turn on? Does the cooling fan ever turn on ? If it doesn't, You can ground the radiator temp switch and see if the fan turns on, if it does, either of the 2 mentioned switches could be faulty. If the fan does come on but the lite also comes on then its probably the switch behind/cover the cover near the overflow bottle.
