February 06, 2026, 08:27:42 PM
permanent mount lift adapter
Topic: permanent mount lift adapter (Read 1365 times)
N0tac0p
May 02, 2013, 10:36:00 AM »
looking on Ebay, cant' tell how it mounts wha tit look like,e tc. anyone have pics of this thing? separate and installed? (or scan instructions?) I bought the original that cradles teh frame and uses "L" bolts into the engine. may go to this new style to keep mounted, just dont' know what it does or how it would work
welder
Re: permanent mount lift adapter
May 02, 2013, 11:50:33 AM »
I put one on my sons bike works great, it bolts to the 2 bolts that hold side stand on. made out of 1 inch tubing with angle iron on top that slides between kick stand bracket and frame.
mmurffy03
03 standard
toms river new jersey
May 02, 2013, 01:52:31 PM »
works fine on my bike also
Lyle Laun
Calgary, Ab
May 02, 2013, 06:27:47 PM »
Here's the one I have. Works very well
http://www.ebay.com/itm/VALKYRIE-HONDA-LIFT-JACK-ADAPTER-NEW-1-MUST-HAVE-MOTORCYCLE-ITEM-Save-/170895926144?pt=Motorcycles_Parts_Accessories&hash=item27ca30e380&vxp=mtr
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Red Diamond
Beaumont, Texas
May 02, 2013, 06:56:30 PM »
If you already have a jack adapter and don't feel like attaching it when you lift your bike, save yourself a little money, use two 2 X 4's about 10 inches long. Set the pieces on the flats of your jack, place the jack under the motor with the rear 2 X 4 toward the rear under the motor. It will lift just fine and is stable. The only reason you need a lift adapter of any kind is that without them the flats on the jack will hit the exhaust headers and cause the bike to rock from side to side.
Mildew
Live, Not Just Exist
Auburn, Ga
May 02, 2013, 07:22:21 PM »
I built a cheapo adapter off of some measurements found on this site.
frosty
Reply #6 on:
May 06, 2013, 07:38:38 AM »
The best part of the mounted adapter mentined is that it is there when you may need it. I was on the road and the U-joint went out. With that adapter on it made things a whole lot easier and safer. Has paid for itself many times over.
