February 06, 2026, 08:27:43 PM *
Author Topic: CB Radio Filter  (Read 1577 times)
Valkyrie Girl
« on: May 04, 2013, 05:48:26 AM »
I have installed a Honda CB on my 2000 Valkyrie Interstate and I'm getting a lot of engine noise.  Anyone know where I can purchase a filter?  Thanks for any and all help!
BonS
Blue Springs, MO
« Reply #1 on: May 04, 2013, 06:30:58 AM »
There are two noise filters on the IS to help quiet the CB. There is a  Noise Suppressor "A" part# 08118-MN500-05. It's connected in the harness at right side neck behind steering stem. Inline connection to the 2-Pin connector (Black). There is also a noise suppressor "C" part# 08118-MN500-07. It's attached at the alternator cable mount and grounded to alternator housing. This is a standard part on the IS.
I believe that this Goldwing air pump noise suppressor is identical to the Valkyrie IS CB noise suppressor "A": http://www.sierra-mc.com/proddetail.asp?prod=HON-GL15-CB-FIL-AP
BonS
Blue Springs, MO
« Reply #2 on: May 04, 2013, 06:47:50 AM »
Oh, and where do you have the CB squelch set??? I'll adjust mine until I can get the weakest riders signals but completely suppress the background noise otherwise. The settings may vary between 10 and 20 for me. I only have the original IS alternator filter/suppressor but I don't have the "A" filter at all. No problem.
Valkyrie Girl
« Reply #3 on: May 04, 2013, 09:00:32 AM »
Thanks for the help.  I'll look into those filters.  I have to turn my squelch up to the point of not being able to hear other riders in order to eliminate the noise.   Sad
« Reply #4 on: May 04, 2013, 03:24:09 PM »
Good grounds on the radio? What is the S W R(standing wave ratio)? You need an S W R meter to check it. And i'm dredging this up from approx. 40 years of messin with the durn things on my big trucks.  uglystupid2 As a side note I have 2 or 3 good C B radios in my garage-where they are gonna STAY.  cooldude Been retired a smidge over 4 years and DO NOT miss them in the least.  Wink RIDE SAFE.
frosty
« Reply #5 on: May 06, 2013, 07:44:11 AM »
I know I have to have the squelch up around 17-20. if not get alot of noise. From what I've saw most others do to on the valk C.B.
