January 28, 2026, 11:01:33 PM *
Author Topic: PILOT SCREW  (Read 2265 times)
jammer
#5407 3 valks 97-98-99
Illinois
« on: June 29, 2009, 01:59:30 PM »
Bike started running bad.  On inspection  I found #4 pilot screw laying on the  engine deck.  Could not tell if there was an O'ring inside.  Replaced pilot screw, bike is running good.
G
G
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 29, 2009, 05:48:30 PM »
if that had been me, the pilot screw would be nowhere to be found.  You found it and that fixed the problem.....like I said.  That was good luck.
« Reply #2 on: June 29, 2009, 06:05:12 PM »
Jammer, go down and buy a lottery ticket RIGHT NOW!!!  You, are the luckiest man alive...  well almost..
Smiley
Hay  Cool
« Reply #3 on: June 29, 2009, 06:13:10 PM »
How long before it falls out again?
Did you not do anything but put it back.  How many turns?
jammer
Illinois
« Reply #4 on: June 29, 2009, 07:47:25 PM »
I rode back over 50 miles after the bike started acting up.  The pilot screw,  the tiny washer  & spring  seperated, were all lying on the engine deck  in various locations.  I replaced it, turned pilot screw in until it seated, then backed  it out 2 1/2 turns.
     The bike is desmogged so there is not much clutter there.  I could not tell with a mirror if there was an O'ring still in the pilot hole.
     Guess I will have to keep an eye out.
G
G
« Reply #5 on: June 30, 2009, 07:55:47 AM »
You can get a set of six o-rings from "redeye' on E-Bay. I think about twelve bucks.
You need the o-ring to help keep the screw from turning out. The spring is an additional help for the same reason.
I think the current wisdom is about 1-1/2 to 1-3/4 turns on the screw.
John U.
Southern Delaware
« Reply #6 on: June 30, 2009, 07:53:10 PM »
The recommended 1 1/2 to 1 3/4 out from lightly seated is for carbs with 38 slow jets. I believe the recommended setting for the oem 35 slows is 2 1/4 to 2 1/2 turns out.
BonS
Blue Springs, MO
« Reply #7 on: July 01, 2009, 05:41:44 AM »
I recently changed to 38's on my 99 IS where the slow jets had never been touched since new and they were all 2 turns out. I just set them to 1.5 turns but haven't given it a test ride yet. Two turns with the 38's was definitely too rich.
