February 06, 2026, 08:29:09 PM *
Author Topic: Does this look right - another question added  (Read 3144 times)
Dr Bobs Patient
Okatie, SC
« on: May 08, 2013, 05:13:39 AM »
(Additional question added in thread below - 5/9/13)
I'm in progress with replacing the u-joint and here's a look at the rear wheel.  The splines themselves are great, the edges have almost a sharp edge to them.  My question is how the grease has spun out from the center.  Is this normal?
Thank you in advance for any help.  This place has been a wealth of information.
DBP
« Last Edit: May 09, 2013, 09:07:35 AM by Dr Bobs Patient » Logged
I keep doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
« Reply #1 on: May 08, 2013, 05:20:57 AM »
Well........that looks about right for having a broken O-ring.  I think that is the spline O-ring stuck to the side of the wheel there.  That also looks like axle grease and probably a heavy application so all things considered, looks good to me.  Get new O-rings for sure
« Reply #2 on: May 08, 2013, 05:24:12 AM »
Spline O-ring was broken on mine this service I just performed.  Undecided BUT all is well on mine also.  cooldude RIDE SAFE.
pancho
Bonanza Arkansas
« Reply #3 on: May 08, 2013, 05:25:12 AM »
There are three o rings in the area to keep that from happening. Do a search and you will find the location of them,, one on the flange, one on the wheel and one in the final drive o ring retainer, they should be replaced at this time along with the thrust washer. All four parts are low price and can be found at HDL parts,, or the o ring set can be found on eBay,, maybe the thrust washer also. The area may have been over lubricated, but better that than not enough,,, all you have is a greasy mess,,, no damage and no wear.
pancho
Bonanza Arkansas
« Reply #4 on: May 08, 2013, 05:28:56 AM »
I agree that is the broken flange o ring stuck to the wheel.
Dr Bobs Patient
Okatie, SC
« Reply #5 on: May 08, 2013, 05:55:28 AM »
Thanks for the help.  I do have in my possession the three O rings as recommended elsewhere on the board.  I am keeping a picture diary of the operation, it'll just take me some time to post as I only have an hour or so each night to work on her.
DBP
Brian
Monroe, NC
« Reply #6 on: May 08, 2013, 06:32:38 PM »
Looks like your timing on this was perfect. This could have ended up badly for you.
F6MoRider
Lakeland, FL
« Reply #7 on: May 08, 2013, 06:55:31 PM »
If the thrust washer is still good, clean it off and reuse it.  Don't forget the moly paste on the thrust washer when you reassemble her.  Also, search the board for the NC shop that has the best ever deal on the 3 o-ring set(s).  Beats other sources by a landslide on price and you get multiple sets so you'll have them on hand next time.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
« Reply #8 on: May 08, 2013, 09:16:27 PM »
   That would be Carolina Bike and Trike.  cooldude RIDE SAFE.
« Reply #9 on: May 08, 2013, 09:21:52 PM »
I don't mean to bring this off topic, or in another direction, but it was mentioned about the thrust washer. I know my Valk IS had one, a very thin plastic disc.
But my 88' GW doesn't. I have also not been able to find the part in either the Valk or the GW fische. I'm trying to find out if it is missing from my bike, and if it missing will cause damage, like has been posted in the past.
PhredValk
Edmonton, Alberta, Canada
« Reply #10 on: May 08, 2013, 09:40:50 PM »
http://www.cheapcycleparts.com/model_years/892-honda-1999-valkyrie-interstate-gl1500cf/assemblies/13494-rear-wheel
99 Valk IS;
#004, Washer, Thrust.
http://www.cheapcycleparts.com/model_years/840-honda-1998-gold-wing-se-gl1500se/assemblies/11963-rear-wheel
98 Goldwing SE;
#007, Washer, Thrust.
Fred.
VRCCDS0237
F6MoRider
Lakeland, FL
« Reply #11 on: May 08, 2013, 10:02:52 PM »
It is needed!  Don't ask me how I know....
I recall a post from someone long ago who was in a pinch and needed one, so they made one out of a plastic milk jug and it got them home.
VRCC #4086
Dr Bobs Patient
Okatie, SC
« Reply #12 on: May 09, 2013, 06:57:09 AM »
Yep bought the O-Rings and Thrust Washer from www.cheapcycleparts.com.  Here's another question - Below is the view into the swing arm drive shaft area and the drive shaft.  I know that this amount of loose grease isn't right.  Is that the oil seal that is at the pinion cup? Part number 16 in this diagram? http://www.hdlparts.com/fiche_section_detail.asp?section=2508621&category=Motorcycles&make=Honda&year=1999&fveh=132117  What do I need to replace here?
The good news is that the wheel dampers are worn very little.  There was little-to-no rubber dust and the metal sleeves are tight in the rubber.  I couldn't remove them by hand but the did slide out easily enough with a small screw driver.
Again, thank you for your assistance.
DBP
« Reply #13 on: May 09, 2013, 10:04:33 AM »
yeah #16 good to go, you might also order the snap ring that holds the spring on.....I dont like reusing them if I dont have to
olddog1946
Moses Lake, Wa
« Reply #14 on: May 09, 2013, 01:00:42 PM »
DBP
For that grease/oil to be that color you've had water in there. I'd take the time to check the u-joint boot for tears. Wouldn't hurt the check the final drive oil for water in it as well.
« Last Edit: May 09, 2013, 01:10:55 PM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Dr Bobs Patient
Okatie, SC
« Reply #15 on: May 09, 2013, 01:32:18 PM »
DBP
Final Drive got drained out, didn't have any moisture in it.  I haven't checked the boot but I do have a replacement for it when I bought the u-joint.  cooldude
« Reply #16 on: May 09, 2013, 05:47:13 PM »
Yes, seems that if you read the parts, you find the thrust washer. Thank you.
However, reading on my 88', no thrust washer.
http://www.bikebandit.com/houseofmotorcycles/1988-honda-gold-wing-gl1500/o/m151628#sch22498
Also the same on the 91', which is my replacement rim.
http://www.bikebandit.com/houseofmotorcycles/1991-honda-gold-wing-special-edition-gl1500se/o/m151582#sch22733
I wonder when the GL1500 started using them, and should I add it in my older bike? ?'s ?'s ?'s, what to do. Post in the GW forum, and see if they have any answer for this.
As for the GW, I mentioned about loosening the 4 bolts on the tube to drive, and the GW "mech" I was with had never heard of this before. Seems strange that the GL1500 was "made better" in the past, and now requires more attention.
Found that post with the missing washer, and what it did to the rear wheel.
http://www.valkyrieforum.com/bbs/index.php/topic,39552.0.html
olddog1946
Moses Lake, Wa
« Reply #17 on: May 09, 2013, 06:35:33 PM »
Looking through the fische on hdlparts.com 96 GW is the first year shown with the thrust washer. Maybe be a difference in the flange depth or shoulder on the wheel.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
