February 06, 2026, 10:08:17 PM *
Author Topic: Slider tube replacement  (Read 1420 times)
« on: May 08, 2013, 05:15:44 PM »
A friend's VTX 1800 has had the right fork rebuilt twice in less that a year. I'm suspecting the slider tube is scored or slightly bent. Can the tube be replaced without having to buy the whole lower fork assembly?
olddog1946
Moses Lake, Wa
« Reply #1 on: May 08, 2013, 06:12:07 PM »
Check out hdlparts.com for the model and year. Looks to me like it can be swapped out.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
YoungPUP
Valparaiso, In
« Reply #2 on: May 08, 2013, 06:15:52 PM »
Just did this last month on the Valk. Hardest part was removing the lower.  Apply heat, turn with axle, apply more heat turn more.  Once you get it turning its good but then it gets hung up on all the built up crap on the bottom of the slider.  Thats when a dead blow or rubber mallet comes in.
99 STD (Under construction)
« Reply #3 on: May 08, 2013, 09:29:44 PM »
Young Pup: I presume the slider screws in/out. Is there a sealant that goes on the threads? How did you spin it in without warping the new slider?
quexpress
Montreal, Québec, Canada
« Reply #4 on: May 09, 2013, 06:27:03 PM »
I do not believe from Honda ... but you can purchase the tube from this place:
http://www.fastfromthepast.com/servlet/the-template/about/Page
I still have a full deck.
I just shuffle slower ...
quexpress
« Reply #5 on: May 09, 2013, 06:30:08 PM »
Young Pup:
Not a young pup ... but I'll give it a try!  Grin
Yes
Yes. Many people have used blue lock tite with success.
There is a hole at the top of the tube. Slide a large screwdriver through this hole and start turning.  Smiley
YoungPUP
Valparaiso, In
« Reply #6 on: May 09, 2013, 07:21:01 PM »
I wrote the old slider tube off and just gave it hell with the vice to hold it. The threads are standard.  After cleaning the threads  in the lower with some brake cleaner and a tooth brush it spun on very easily with some blue loctite.
« Reply #7 on: May 09, 2013, 07:43:37 PM »
Thanks guys.
