February 06, 2026, 10:08:22 PM *
Author Topic: Radiator grill rattle  (Read 1199 times)
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« on: May 08, 2013, 08:00:50 PM »
Been noticing a rattle noise when riding. The left side radiator chrome is tight, but the right side is loose. It pivots from about the middle point. I can easily rock it. Seems like this could be the noise.  How is this mounted, and how can it be tightened up.
Farther
Quimper Peninsula, WA
« Reply #1 on: May 08, 2013, 08:10:40 PM »
Remove reflector, tighten mounting screw, throw away reflector, clean off mounting tape residue.
~Farther
tonyfan70
Apparently they know you?
Central Illinois
« Reply #2 on: May 11, 2013, 07:59:33 AM »
I have a rattle coming from that area as well when I go over bumps. Mine isn't coming from the sides though. From what I've found, my problem is the mesh part slaps against the radiator itself. Not real sure how to quiet that down, maybe put a small piece of rubber between the rad and the grill.
1997 Standard. Original bumblebee tin stored.
1998 Magna 750
2000 POS Sportsman 500
« Reply #3 on: May 11, 2013, 11:36:24 AM »
On mine we shot a small squirt of silicone in each corner.
Pushed on each corner to make sure it got a chance to stick.
Crude way to fix, but it worked.
pancho
Bonanza Arkansas
« Reply #4 on: May 11, 2013, 12:26:54 PM »
When you remove the reflector, you may find the ABS plastic broken up around the screw mounting area,,, if so, a clunky repair with ABS cement or what R J said.
Jruby38
Oxford Mass.
« Reply #5 on: May 12, 2013, 08:42:11 AM »
I had a rattle in the front end too.  The radiator top bolt was loose and I shimmed the cover with some strips of foam insulation to fix it.
