February 06, 2026, 10:08:22 PM *
Author Topic: Charging capacity  (Read 1541 times)
Relax
Power & elegance...just like the Valk
Oslo, Norway
« on: May 09, 2013, 03:42:24 PM »
My volt meter says 12,6 V before start and 14,2 when running ,,,
After adding a set of hedlamps  (55 W x 2), my volt meters say 13,8 when running...
It is pretty much all extras on the bike those 2 lamps,,
is it as expected? ..that 2 x 55 W create this loss...or is it s short cut or somethings ... "tired# generator?
valk standard, 2001 , 120 000 km,, ( 80 000 miles) , original generator
Smiley
pancho
Bonanza Arkansas
« Reply #1 on: May 09, 2013, 03:48:59 PM »
I don't think there is any problem there at all,, things are working just fine. You are getting about the time to check/replace the brushes in the alternator, but I don't think it is causing you a problem at this time. Just to check, leave the headlights on for a couple of minutes with the bike off, then start it and rev it while monitoring the voltage, see if it goes to 14+.
silver337
San Diego, Ca
« Reply #2 on: May 09, 2013, 04:20:25 PM »
It's a fact when amperage goes up voltage drops.
« Reply #3 on: May 09, 2013, 05:53:27 PM »
My old rememberer seems to recall 548 watts is the charge capacity.
Relax
Oslo, Norway
« Reply #4 on: May 09, 2013, 11:28:26 PM »
When i do this it goes easily to 14,2 V when those light extra lights are off ...
IF brushes are about to be worn out , does charging suddenly stop or bit by bit?
Should I cancel a 2 week ... 3000 miles ...ride until i got it replaced , you think ?
pancho
Bonanza Arkansas
« Reply #5 on: May 10, 2013, 05:28:24 AM »
I wouldn't,, unless you just dont want to go. I dont think you have any problems,, check the alt. when you come back.
jimmytee
Elizabethtown,KY
« Reply #6 on: May 10, 2013, 05:58:13 AM »
Hey Pancho,,,hey Sisko  Grin Grin
pancho
Bonanza Arkansas
« Reply #7 on: May 10, 2013, 06:04:10 PM »
Hold on Relax,,, how long do you have before the trip???  It only takes a couple of hours to remove to remove the alt. disassemble and check the brushes,,, just for piece of mind.  If you are not up to that level of work, maybe someone is close and can help,, its not very involved just to check .
The Cisco kid    he was a friend of mine
jimmytee
Elizabethtown,KY
« Reply #8 on: May 10, 2013, 07:36:14 PM »
Grin that's right it was with a "C"
