January 28, 2026, 11:03:54 PM
I/S Headlight Adjustment - Not Enuf
Topic: I/S Headlight Adjustment - Not Enuf (Read 2002 times)
Marty_in_MN
June 30, 2009, 05:27:00 AM »
Hi Everyone:
I put SilverStar 9003 headlight bulbs in my I/S by grinding one of the three tabs off the bulbs. I did not use any adapter rings. The other night I tried to adjust them vertically downward using the two top knobs behind the front fairing. The beams did move after after a few (or more) full turns, but not as much as I would like. I was hesitant to turn the knobs anymore.
Has anyone ran into the same problem, not getting enough vertical adjustment, too?
Marty
1FAST6
Sanford, NC
Re: I/S Headlight Adjustment - Not Enuf
June 30, 2009, 07:25:40 AM »
I did the same thing with PIAA bulbs and had no problems, as I believe many others have as well, without the adaptors. Did you remove the fairing to install them or just try to reach up from behind. My hands are too big to get in there, so I always pull the fairing. Not too tough and can be done in under 10 minutes (in the parking lot of a Chinese restaraunt). You may want to check to make sure they are properly seated...
June 30, 2009, 07:37:37 AM »
Where your rear shocks are adjusted will have an effect on the vertical aiming of the head lights.
June 30, 2009, 12:27:17 PM »
It takes a lot of turns of the knobs to move it much. hoser
PAVALKER
Pittsburgh, Pa
June 30, 2009, 02:43:37 PM »
I used the adapters when I installed my Silverstars and have had no need to adjust them. I thought that was the reason for using the adapter to begin with, so that they would be aimed correctly for adjustment purposes??? With the adapters it worked well...
John
sugerbear
wentzville mo
June 30, 2009, 04:20:58 PM »
i've done it with and without the rings.
i like the rings.
my 2cents
T.P.
Apple Valley, Minnesota.
HEY MARTY !
Reply #6 on:
June 30, 2009, 05:21:33 PM »
shop talk enclosed, cut off the two bottom tabs
http://www.valkyrieriders.com/shoptalk/interstateheadlight.htm
