January 28, 2026, 11:01:34 PM *
Author Topic: hand grip removal  (Read 2173 times)
boppa
Rome, Ga
« on: June 30, 2009, 05:35:26 AM »
I need some advice on the best way to remove the oem grips on my I/S.
It feels like I can just twist the left grip and it wil come loose but not sure about the throttle side,don't want to break anything. Thanks in advance.
Daniel Meyer
The State of confusion.
« Reply #1 on: June 30, 2009, 05:41:09 AM »
On the throttle side, the chrome cap on the end un-screws. Then you can slide the grip off, but it may need a little wd-40 squirted underneath it.
CUAgain,
Daniel Meyer
Master Blaster
Deridder, Louisiana
« Reply #2 on: June 30, 2009, 05:45:23 AM »
Clutch side pry off the cap, throttle side unscrew.  After caps are off wedge the tip of a blow gun under the edge and  hit it with compressed air, it will twist right off sans any damage.
vanagon40
Greenwood, IN
« Reply #3 on: June 30, 2009, 06:00:37 AM »
http://bigbf.com/bigbf_shop/grip_criuse/index.htm
Here are some pics of removal and replacement with Kury grips.
As another commented, if you do not have compressed air, try WD40.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: June 30, 2009, 06:23:31 AM »
Mine would not come off, with any method. I cut them off with a razor blade. I know this is not the preffered method, however I got impatiant and they were pretty well destroyed and wheathered anyway. That was when she got her new Kury grips.
boppa
Rome, Ga
« Reply #5 on: June 30, 2009, 10:55:10 AM »
Thanks for the replys, they should help make the swap fairly easy.
