February 06, 2026, 10:09:20 PM *
Author Topic: 1999 Valk....PLEASE HELP...Vent Line Questions  (Read 1221 times)
SteveF6
« on: May 13, 2013, 03:54:36 PM »
Hey Guys...My first Post.  Glad I found this forum.
I just bought a very clean 1999 Valkyrie....She sat up for a year or so prior to my purchase.
This weekend I removed the carbs, broke them down and cleaned main jets, slow jets, float valves, floats, bowls......everything.  I removed the vent lines to replace them but have run into a problem.
.....I am unsure of the carb numbering but there are open nipples on the chrome intake tubes on both sides...Only two of them had tubes hooked to them.
.....the secondary air supply control valve that is perched in the center of the carb next has a tube running from it into a "T" with tubes running from them.
.....the petcock has a vaccuum fitting to the right of the fuel line......
I CANNOT REMEMBER THE ORDER OF ASSEMBLY....LOL!!!!!!
I know, I know....take notes and pics....I guess I was excited...
I welcome phone calls as well....205-461-3502
Thanks in advance....I am really wanting to ride and right now all she will do is idle for a few seconds with full choke.....
Please Help!!
Steve
Daniel Meyer
The State of confusion.
« Reply #1 on: May 13, 2013, 04:03:13 PM »
The vacuum port on the petcock hooks to the #6 vacuum port (back left intake port).
The two lines on the T from the CV hook to the two center cylinder intake vacuum ports.
CUAgain,
Daniel Meyer
SteveF6
« Reply #2 on: May 13, 2013, 04:05:06 PM »
Here comes the stupid question....where is the #6 vac port located.....????
Thanks for the quick reply!!!!
tank_post142
south florida
« Reply #3 on: May 13, 2013, 04:09:33 PM »
sit on bike. rear left carb. port is on the intake tube below the carb. on the inside side
I got a rock Sad
VRCCDS0246
bill-jr
VRCC # 35094
murfreesboro
« Reply #4 on: May 13, 2013, 04:23:57 PM »
my bike has the front two on right side and front one on left side capped off??? desmog has not been done is this normal??
99' Black tourer
« Reply #5 on: May 13, 2013, 04:56:01 PM »
Right side is #'s 1-3-5  Left side is #'s 2-4-6  (Front to rear)
#3 & 4 have vacuum lines to a T under the carbs and then it runs up to the PAIR valve actuator.
#6 had a vac line to the petcock.
The others have Vacuum caps.
SteveF6
« Reply #6 on: May 13, 2013, 05:07:08 PM »
Thank You for the help....Got her running.....But there are a few other issues.  Ill create another thread.
Steve
9Ball
« Reply #7 on: May 14, 2013, 04:56:52 AM »
no...see the post directly below yours for the factory setup.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
SteveF6
« Reply #8 on: May 14, 2013, 05:41:04 AM »
Perfect....I have everything set to factory now.  I now need to buy a rebuild kit for the carbs....Would you guys suggest a DynoJet or just factory main jet, slow jet and float valve?
tank_post142
south florida
« Reply #9 on: May 14, 2013, 06:36:45 AM »
pull and clean them again. soft copper wire through all ports and jets until everything is spotless! you can get copper wire by stripping a section of multi-strand wire and untwisting the core.
I got a rock Sad
VRCCDS0246
SteveF6
« Reply #10 on: May 14, 2013, 11:03:12 AM »
Thanks Again Tank!!
Steve
