February 06, 2026, 10:08:36 PM *
Author Topic: Carburetor Help!!! 1999 Valkyrie  (Read 1774 times)
SteveF6
« on: May 13, 2013, 05:16:34 PM »
Hey Guys....Did a complete carb clean out this weekend.  She sat up for a year or so prior to my purchase.  I didnt find a ton of crap in the carbs or bowls but did have 2 float valves stuck.  Careful negotiation got them out....
I just put everything back together (mixture screws all 2.25 out) and she will run but will not idle.  Spits and sputters.  I road it down the street and back and she struggles to stay running at low RPM.  I did notice some fuel dripping down from the overflow lines from the carbs.
Would you guys guess I have a stuck float valve again.  I do know all cylinders are firing.
Do you think ordering a rebuild kit would be the best thought....Should I step up from a 135 to a 138 Main?
Thank You for reading and I appreciate any help you can give.....
Steve
CajunRider
Broussard, LA
« Reply #1 on: May 13, 2013, 05:22:16 PM »
If you're dripping fuel from the overflow, you prolly got a stuck valve.  I'd check that before anything else.
Sent from my Apple IIe
« Reply #2 on: May 13, 2013, 05:24:53 PM »
no idle , pilot jets are clogged.
stock main jets are 100.
u sure u have 135s awful large for a stock bike?
SteveF6
« Reply #3 on: May 13, 2013, 05:39:19 PM »
@CA....Not sure.  I have read a few posts about jet sizes.  I did not look at the jet number when I had her apart.
@Cajunrider....I think you are right....I am going to order a rebuild kit and see if i cant get her on the road.
Thanks Guys.
Steve
Thunderbolt
Worthington Springs FL.
« Reply #4 on: May 13, 2013, 07:12:01 PM »
I have cleaned up about 6 or 7 sets of carbs.  One set the floats were stuck and once you turned the fuel on and cranked it over, it would overflow.  After cleaning it up one side overflowed again.  Another removal and cleanup and I think the key was afterwards running some fuel through all the carbs with the drains open to flush everything out.  I also put a new screen in the tank and a petcock repair kit.  Make sure the tank is clean and that enough fuel flows through the line to flush out whatever residual trash remains.  I picked up a trick from John Schmidt and use an external tank to check to make sure there are no stuck floats before I install the carb bank.  That way you don't have to take them back out again. Smiley
al v
Clinton Township, MI
« Reply #5 on: May 13, 2013, 07:22:20 PM »
Did you mean to say, "Should I step up from 35 to 38's for the slow jets?"
BonS
Blue Springs, MO
« Reply #6 on: May 13, 2013, 07:44:46 PM »
A stuck float can often be freed by bonking on it with a dowel or handle of a screwdriver. Worth a try before tearing down everything. Just don't overdo it and break something.
« Reply #7 on: May 13, 2013, 07:59:44 PM »
+1 you might also try chemical additives to clean things up. I like Chemtool B12, a full can to your next fillup and run it all out right away.
My rides:
SteveF6
« Reply #8 on: May 14, 2013, 05:45:27 AM »
I appreciate you guys....everyone is so very helpful.
As I said, I can get it to start with no problem but she will not idle.  It will only start under full choke....The fuel spilling out of the carbs has stopped.
Would the chemical additive be the next step you guys would take?
BonS
Blue Springs, MO
« Reply #9 on: May 14, 2013, 06:33:13 AM »
You can try driving it clean with heavy doses of Techron. Put a full bottle in a full tank and drive it. Let it sit and drive it some more. It could take a tank or two to open up the slow jets. The other option, and the one that I take, is to replace the slow jets with 0.035's (OEM).  Or you can bump up to 0.038's, that many like to enrichen the slow speed circuit,  and set your  mixture screws to about 1.75 instead of 2.5 turns out if you go with 0.038's.
tank_post142
south florida
« Reply #10 on: May 14, 2013, 06:38:51 AM »
remember: to ensure cleaning of the slow jets you need to run at low rpm then let it sit, do this a number of times. this allows your solvent to enter the low speed circuit.
I got a rock Sad
VRCCDS0246
SteveF6
« Reply #11 on: May 14, 2013, 11:01:07 AM »
Thanks very much guys!!!!   I will let you know the progress.  I am so ready to ride this bike!
It has been my dream bike since the day it was build.....NOW I OWN ONE AND HAVE NOT BEEN ABLE TO RIDE IT!!!   tickedoff
In Due Time!!
Steve
« Reply #12 on: May 15, 2013, 08:01:10 AM »
In Due Time!!
Steve
Hang in there, it's worth it! cooldude
My rides:
