February 06, 2026, 10:08:33 PM *
Author Topic: Leak at #6 intake manifold  (Read 2140 times)
vanagon40
Greenwood, IN
« on: May 14, 2013, 07:17:17 AM »
Something is leaking onto the head at the #6 intake manifold.  I have not searched real hard, but not sure where it's coming from.
I have taken nothing apart, ever, except to change the air filter several years ago.
2001 Standard with 31,000 miles.
olddog1946
Moses Lake, Wa
« Reply #1 on: May 14, 2013, 07:19:46 AM »
Get a set of intake O rings from Redeye tech and you'll be good to go. Easy to change out.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #2 on: May 14, 2013, 07:20:24 AM »
Intake O-ring leaking. If i'm wrong someone will correct me. RIDE SAFE.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #3 on: May 14, 2013, 08:40:36 AM »
Yup...  Intake O-Ring leaking.  Easy fix, and do 'em all while yer gettin' busy  Wink
Link to the Red Eye kit...
http://redeye.ecrater.com/p/2064055/intake-o-ring-kit-viton-gf
Black Dog
Don't you know...
« Reply #4 on: May 14, 2013, 08:52:21 AM »
It does look like the intake o-ring and its easy to fix, but, I'd also check the vacuum line to the petcock. The diaphram can leak and the line can be cracked/split.
« Reply #5 on: May 14, 2013, 09:21:25 PM »
Looks like you've had some rodent on the top of your bike, doing his business.
OK. Looks like a O-ring leak also.
Maybe a little soap and water to see if there is a leak?
« Reply #6 on: May 14, 2013, 10:18:56 PM »
Looks like MGM did when the neighbors dog pissed on the motor.
If I could of caught him in the act he would have been in Doggie heaven now.
vanagon40
Greenwood, IN
« Reply #7 on: May 15, 2013, 08:00:48 AM »
. . . .  Maybe a little soap and water to see if there is a leak?
Yep.  There was yellow residue by the manifold and I cleaned it all off before riding to work.  17 miles later in the parking lot I took the above photo in the original post.
Maybe there was a mouse hiding and the high speed ride scared the piss out of him?
***Edited for clarity***
« Last Edit: May 15, 2013, 11:15:25 AM by vanagon40 » Logged
« Reply #8 on: May 15, 2013, 08:21:37 AM »
Yep.  There was yellow residue by the manifold and I cleaned it all off before riding to work.  17 miles later in the parking lot I took the above photo.
Is it just me or are my eye giving out?    I don't see another picture.
« Reply #9 on: May 15, 2013, 08:35:46 AM »
Like others said O-ring leaking. I would also replace all your vacuum lines and synch port caps. Redeye has all you need to do the job.
My rides:
