February 06, 2026, 10:09:26 PM *
Author Topic: starter issue  (Read 1000 times)
DirtyDan
Kingman Arizona, from NJ
« on: May 14, 2013, 06:00:40 PM »
hey guys
 ive been having and intermitent problem with my starter for a while now. some times when i hit the button nothing happens. its not the clutch saftey switch because it happens in neutral also. its not the battery that has plenty of umphh. its not the starter button because ive had that changed several times. so i am out of ideas. its a 97 standard with 126k VERRY hard miles with frequent stops and starts {pictures and smoke breaks} any help would be appreciated
thanks dan
CajunRider
Broussard, LA
« Reply #1 on: May 14, 2013, 06:15:00 PM »
Give the starter relay a check.
The leads on mine were melted, as was the main (hot) wire going into it.  I rewired the whole thing and things got a little better for me.
Sent from my Apple IIe
pancho
Bonanza Arkansas
« Reply #2 on: May 14, 2013, 06:17:39 PM »
Does the starter relay click?? Check the connections on it. Got to start somewhere.
« Reply #3 on: May 14, 2013, 06:20:21 PM »
Even tho you've replaced the starter switch, I'd take it apart and clean it.
Battery terminals tight?
Check the easy stuff first.
« Reply #4 on: May 14, 2013, 06:32:09 PM »
Take the battery cables off the engine ground, clean em up good, put them back together.     They will corrode real easy.    I run my cable to the frame, and then added a short cable from there to the aluminum engine mount.    Oh, I forgot, the cable to the aluminum engine, when yea get it clean and remounted, paint it with clear finger nail polish.     That seems to give it a nice seal so as to keep that corroding out.
