Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« on: May 14, 2013, 06:30:34 PM » |
Which oil is the best for the final drive?
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing. GEORGE ELIOT
« Reply #1 on: May 14, 2013, 06:33:43 PM » |
I run 75/90 Castrol full synthetic. The rear gear case stays cool even on the hottest days.  RIDE SAFE.
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #2 on: May 14, 2013, 06:41:23 PM » |
I hope I haven't hurt anything....I've been running Mobil 1 75W-140 for the last 15,000 miles...
« Reply #3 on: May 14, 2013, 06:51:34 PM » |
That will work very well. Good stuff. Hoser
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #4 on: May 14, 2013, 06:54:35 PM » |
That will work very well. Good stuff. Hoser  Hoser, the 140 is not to high?
« Reply #5 on: May 14, 2013, 09:34:46 PM » |
In a word, no. the multi viscosity rating means it is suitable for use with any spec that is called for within that range.
« Reply #6 on: May 14, 2013, 09:39:12 PM » |
The GL5 rating needs to be on the bottle. It's a common rating and on most gear oils you find.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #7 on: May 15, 2013, 04:05:49 AM » |
Redline Mt 90. $18 quart though. I put some in my manual tranny in my car. It's a little thick . Hard shifting in the morning then it's quiet as a mouse after 30 miles or so.
« Reply #8 on: May 15, 2013, 05:01:32 AM » |
This oil is not a hypoid gear oil (GL-5). It is a transmission oil and not suitable for the Valkyrie final drive. http://www.redlineoil.com/product.aspx?pid=46&pcid=7a quote from the site above: MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears
« Last Edit: May 15, 2013, 05:07:49 AM by Chrisj CMA »
indybobm
« Reply #9 on: May 15, 2013, 05:07:35 AM » |
I use Mobil 1 GL5 75w140 Synthetic. The final Drive does stay much cooler with this than it does with regular lube. It also looks much better when you change it.
So many roads, so little time VRCC # 5258
« Reply #10 on: May 15, 2013, 06:23:00 AM » |
I use amsoil 500k mile 75w90 and add a moly supplement as if came from the factory. if one wants even more protection use their high shock servere gear 75w90.
the use of 140w just waste fuel. the reason it has come about is for EPA extended drain requirements, or otherwise known as life time fill by the manufacturers. whereas over time all oil starts to shear down to lower weights. This epa requirement happened in '96-'97 time frame. this is part of a zero discharge policy by the epa. they are even pushing for 100k oil changes for new vehicles. there are already some new vehicles where the transmissions and diffs have no drain plugs.
and a higher viscosity oil always causes a small rise in operating temp.
« Last Edit: May 15, 2013, 07:04:35 AM by CA »
« Reply #11 on: May 15, 2013, 06:58:05 AM » |
It won't hurt your gears, but may cause a wee bit more fuel usage due to the increased resistance of the more viscous oil.
Mildew
Auburn, Ga
« Reply #12 on: May 15, 2013, 09:00:20 AM » |
This oil is not a hypoid gear oil (GL-5). It is a transmission oil and not suitable for the Valkyrie final drive. http://www.redlineoil.com/product.aspx?pid=46&pcid=7a quote from the site above: MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears I'm glad you said something. I have a ½ quart left. I was fixin to dump it in
