February 06, 2026, 10:09:15 PM *
Author Topic: shorty grab rail  (Read 2112 times)
pancho
Bonanza Arkansas
« on: May 15, 2013, 11:48:33 AM »
Where does the short grab rail come from I see on so many of the bikes??  I want to replace the tall one with the passenger back rest mounted on it with one of those short ones.
Bone
« Reply #1 on: May 15, 2013, 12:48:28 PM »
Bought this one in 07 for about $43 from HDL if you meant solo rack.
mmurffy03
03 standard
toms river new jersey
« Reply #2 on: May 15, 2013, 01:31:59 PM »
http://store.valueaccessories.net/valkyriegrabrailsmallsissybarattachestooemhondabackrestmountingbrackets.aspx
« Reply #3 on: May 15, 2013, 03:58:03 PM »
I have this one....
http://www.bigbikethings.com/CruiserBar.html
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #4 on: May 15, 2013, 06:21:47 PM »
Below is what I have.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
pancho
Bonanza Arkansas
« Reply #5 on: May 15, 2013, 07:02:11 PM »
Yep, those are what I was looking for,, although $75 seems a bit high for what it is,,, I may have to bend something up, and chrome it in a bucket. Actually, as I think about it, I have some chrome tubing about the right size I will look at, see what I can do.
Edvalk
Dayton Ohio
« Reply #6 on: May 15, 2013, 08:58:10 PM »
Just call me cheap but $75 is just to much for that grab rail. I just took off the brackets for the back rest.
1998 valkyrie standard , 2007 Suzuki Bandit 1250
Regis
Columbus, In.
« Reply #7 on: May 16, 2013, 05:28:50 PM »
I made 1 out of stainless steel , looks great .
« Reply #8 on: May 17, 2013, 04:52:13 AM »
So did Frank Smoak... and it looks great. His is curved, a perfect arc, instead of being
angular.
pancho
Bonanza Arkansas
« Reply #9 on: May 17, 2013, 08:18:15 AM »
I'd like to see a picture of yours if you have one Regis.
Regis
Columbus, In.
« Reply #10 on: May 17, 2013, 09:28:02 AM »
I will send you PM
Regis
Columbus, In.
« Reply #11 on: May 17, 2013, 10:05:23 AM »
I tried a few times to PM you from my ph . Hope you got 1 , maybe 5-6 !
Regis
Columbus, In.
« Reply #12 on: May 17, 2013, 10:20:46 AM »
Gavin Sons got me a pc of SS and I made it from it . Its 1"x 3/16" stock . I had to trim both sides to fit down on rails but I think it looks better than some of the purchased 1s because its wider . I made this one flat , no arch ,radius or otherwise  and its very strong . It wont bend accidently anyway . Takes alot of polishing but well worth it . Im cheap too !
jimmytee
Elizabethtown,KY
« Reply #13 on: May 17, 2013, 04:19:06 PM »
 cooldude FWIW I've seen it (Regis's stainlees bar), looks nice
pancho
Bonanza Arkansas
« Reply #14 on: May 17, 2013, 04:26:43 PM »
I got them Regis,,,,,  looks pretty good, good solid handhold.
Regis
Columbus, In.
« Reply #15 on: May 17, 2013, 04:39:11 PM »
started making another 1 today , about 75% done . this 1 isnt takin as long .
pancho
Bonanza Arkansas
« Reply #16 on: May 17, 2013, 07:23:38 PM »
Yeah, I could see how it was cut to fit the brackets,,, what did you use to bend the bar?
Regis
Columbus, In.
« Reply #17 on: May 18, 2013, 04:19:08 AM »
the 1 in the pics I sent you I just put in a vise and pulled while hitting with a 2 pound sledge . but the 1 I'm making now I used a torch to heat it and it worked better and got a tighter angle . the bluing from the torch  polished  right out no problem . Cutting , or grinding the excess material from both sides to fit between the rails is the real work . Drilling it is a chore also . But all in all they look decent and make changing from passenger seat to solo a breeze . I used a 1/4 " die grinder and buffing pads to do most of the polishing then finished up with different grades of sandpaper with 600 being the finest .
