February 06, 2026, 10:01:55 PM *
Author Topic: help me diagnose an electrical gremlin?  (Read 1476 times)
upjeeper
« on: May 15, 2013, 06:03:28 PM »
the bike started last week, but leaked fuel from cracked hoses. so i removed the tank and the (*&!#) air box, replaced the fuel lines then replaced the tank. now when i hit the starter button the lights dim and the starter sort of clicks, but doesn't even turn over.
it's been on a battery tender all winter and i even jumpered a car battery (i know, not the best plan) and confirmed the same. so it shouldn't be the battery.
i again removed the tank and airbox last night, can't see any loose connections
any thoughts would be greatly appreciated
YoungPUP
Valparaiso, In
« Reply #1 on: May 15, 2013, 06:19:58 PM »
Have you checked to see if you've got a cylinder full of fuel?  OR taken the battery out and had it load tested?
99 STD (Under construction)
Chiefy
Sarasota, Florida
« Reply #2 on: May 15, 2013, 06:21:44 PM »
The headlight should go OFF, not dim.  If it's not going off, and a jump didn't help, I would look at servicing the starter switch, instructions are in the "shoptalk" section, link above.
upjeeper
« Reply #3 on: May 15, 2013, 06:23:19 PM »
i have not checked the cylinders, and have not removed the battery for load testing.
i have cleaned the started button in the past, might just be time again.
i'll have to check again, maybe the headlight did go off, i don't recall exactly
Denny47
#34898
Grove, Ok.
« Reply #4 on: May 15, 2013, 06:27:18 PM »
Make sure your batt connections are clean and tight. Check the connector on the starter relay, use some CRC spray on the contacts to clean them then apply a small dab of dielectric grease to each contact
USAF 66-70, F-105 AWCS
« Reply #5 on: May 15, 2013, 06:49:49 PM »
To start your bike, there is the battery, starter switch (relay with IS model), all the safety/kill switches, and then the starter relay.
If the jump battery was good (from your daily driver, not running), and that didn't start the bike. Then power should not be an issue.
Like already mentioned, starter switch cleaning link. Verify what your lights are doing.
I'm thinking more the starter relay. Good to be inspected and maybe cleaned/di-electric grease.
Did I miss anything?
« Last Edit: May 15, 2013, 06:54:54 PM by gordonv » Logged
Oklahoma_Valk
Central OK
« Reply #6 on: May 15, 2013, 07:39:28 PM »
Leaky fuel + starter clicking.....
The very first thing I would do is pull the spark plugs,, and try to start it THEN. Hydrolock is nothing to mess around with.
Let those who ride decide.
al v
Clinton Township, MI
« Reply #7 on: May 15, 2013, 10:12:19 PM »
You can also test for hydrolock by putting the bike in 5th gear and pushing it. If the engine turns freely you should be good.
john
tyler texas
« Reply #8 on: May 15, 2013, 10:42:55 PM »
             " Make sure your batt connections are clean and tight "
      both ends           cooldude
vrcc # 19002
upjeeper
« Reply #9 on: May 19, 2013, 02:41:27 PM »
winner winner chicken dinner!!
pulled all 6 plugs (was time for a swap out of them anyway), hit the starter and WOOSH went the fuel.
thank you sir!
Oklahoma_Valk
Central OK
« Reply #10 on: May 19, 2013, 05:43:16 PM »
Glad you figured it out! Now the real work begins. Where can I pick up my chicken dinner?
Ride safe
Farther
Quimper Peninsula, WA
« Reply #11 on: May 19, 2013, 07:30:43 PM »
I think YoungPUP gets the dinner.  police
~Farther
al v
« Reply #12 on: May 19, 2013, 08:05:41 PM »
Just be sure to figure out and fix the cause of the hydrolock before it happens again. Sounds like you got lucky this time if nothing broke.
