February 07, 2026, 11:32:24 AM *
Pages: 1 [2]   Go Down
Author Topic: blower installation : my progress  (Read 12920 times)
Anthony
Belgium
« Reply #40 on: August 18, 2013, 04:38:33 PM »
the problem with this setup is that my fuel valve still hits the silicone tubing, even after cutting the corners ar sharp as i think is possible.
i am going to get rid of that fuel valve, and try to mount a direct bung on the tank, with a shut off valve type AFC161, which has a 0.3125 orifice and a 3/8 NPT connection.
in the upgrade kit i received from Magnacharger the Mikuni 45 HSR was equipped with a main jet drilled to a size 220, and a needle 8CFY2-97, with the clip in the 3rd position.
i had already set the needle 1 notch higher after a couple of test runs.
this week  i went to the dyno to check air ratio's and power.
i was happy to find the following, on the first run :
- needle setting in 4th notch gave correct air ratio while on the needle  cooldude
- 140bhp@ 6058 rpm and 186.4 Nm (= 137 ft lb) @ 4891 rpm.
after drilling out the main jet to a size 230, i ended up with a 145 bhp at 5934 rpm, and 187.7 Nm (= 138.4 ft lb) or torque  Grin Grin Grin Grin Grin Grin
unfortunately i also found she start to ping above 6000 rpm, so i will have to address the timing.
Fortunately i got a contact on a company that produces fully programmable ignition modules, mostly for racing purposes, but also produces one of a kinds, for a very reasonable price.
i will keep you posted how this evolves.
if someone wants me to inquire also for a US model, i need to send a clear high res picture or schematic showing all cable colors and their position on the ICM connector.
a wiring layout i have.
i guess a numbered schematic will also do.
to be continued.
Anthony
Oklahoma_Valk
Central OK
« Reply #41 on: August 19, 2013, 02:20:57 AM »
Awesome. Thanks for an update!!!
Let those who ride decide.
Pages: 1 [2]   Go Up
