April 29, 2026, 02:10:45 AM *
Author Topic: Radiator fan  (Read 2212 times)
mooserider
Blue Knights TX6, Ride with Pride
La Porte, Tx
« on: June 30, 2009, 02:52:32 PM »
working on a 2000 interstate, I just replaced the vac lines, fuel lines, air filter and spark plugs. The bike seams to be running a lot better. I had it idling in the drive way and noticed the cooling fan is not coming on. I drove it home from the owners house aprox 70 miles but it was strait freeway so it had air moving across the engine and I never paid attention to see if the fan had came on.
 Is there a way to manually check the fan motor with out taking the radiator / fan off the bike? I located the black plug in the neck that goes to the fan. I wonder if I can disconnect and add power / ground to the plug to check the fan ?
TIA Keith
Ride with Pride
godfire
Republic of Texas
« Reply #1 on: June 30, 2009, 03:40:09 PM »
That will work as long as you get the polarity right.
The Fan motor switch is located lower left side of the radiator.
If you unplug it you should be able to short the two terminals in the plug....not the terminals on the radiator...and the fan should spin.....The fan has a constant 12 applied to it, and the switch supplies ground. So should work and minimal sparks.....Use this advice at your own risk    laugh
« Last Edit: June 30, 2009, 05:55:48 PM by godfire » Logged
Ride Safe
Ride Often
mooserider
La Porte, Tx
« Reply #2 on: June 30, 2009, 04:06:50 PM »
 Thanks for the tip, I grounded the plug and nothing happen. I wonder if it means the fan is bad?
  Thanks Keith
Ride with Pride
Tinman
Manvel Tx
« Reply #3 on: June 30, 2009, 05:40:29 PM »
Check the fuse! I helped a friend pick up a Valk and it ran fine till we got into some stopped traffic.
The light came on and we pulled over.
The fuse was blown. We replaced it and it blew immediately.
Turned out that a dirt dobber welded the fan to the radiator.
godfire
Republic of Texas
« Reply #4 on: June 30, 2009, 05:59:14 PM »
Yes of course check the fuse, and give the fan a spin.
The fuse should have been the first place to look, sorry.
Ride Safe
Ride Often
mooserider
La Porte, Tx
« Reply #5 on: June 30, 2009, 06:42:51 PM »
 I will track down the fuse tomorrow and check that. I found a couple dirt dobber nest in the engine I'll also check the fan and make sure it spins freely
  thank you for your help
Keith
Ride with Pride
mooserider
La Porte, Tx
« Reply #6 on: July 01, 2009, 11:42:49 AM »
Okay I checked the fuse it was blown, I put in a new fuse, I put a ground to the fan motor switch I could hear the fan like it wants to run then pops the fuse. I'll have to pull the radiator and check the motor next.
Ride with Pride
mooserider
La Porte, Tx
« Reply #7 on: July 02, 2009, 09:59:39 AM »
Final Update I pulled the radiator and found a couple dirt dobber nest holding the fan blade. Removed them put every thing back together and it runs great.
Thanks everyone for your input
Keith
Ride with Pride
godfire
Republic of Texas
« Reply #8 on: July 02, 2009, 12:01:50 PM »
Just like Tinman said.  Two thumbs up Tinman  cooldude cooldude
Glad you got all the bugs worked out worked out Mooserider....bugs....get it.... 2funny
Ride Safe
Ride Often
