February 07, 2026, 12:08:40 AM *
Author Topic: 1997 Tourer Tail Light?  (Read 1335 times)
Scooby
« on: May 22, 2013, 07:49:37 AM »
I have not bought any new bling for my scooter for a long time, so Iam thinking about the rear tail light.  Is there a LED or a brake modulator that can be installed to make that area brighter or flashier?  I think it may be a good idea for others to see that Iam braking too, always thought the stock tail light was a little dim in the visability department.
Thanks-Scooby
NITRO
Eau Claire, WI
« Reply #1 on: May 22, 2013, 07:53:23 AM »
The modulator and LED topic has been covered before, do some searchingand you'll find excellent info. I personally use a Kuryakyn unit for both.
When in doubt, ride.
« Reply #2 on: May 22, 2013, 08:18:12 AM »
Check thru the links in this thread Scoob.
http://www.valkyrieforum.com/bbs/index.php/topic,55486.0.html
ricoman
Sarasota, FL
« Reply #3 on: May 22, 2013, 08:19:55 AM »
nother way to  consider is the Signal Minder which makes your rear turn signals act as running lights and gives yo more visability. It's pretty much plug and play. You may have to make the lenses red (couple light coats of Testor's Transparent Candy Apple Red from the hobby store).
That plus an additional LED brake light will do the trick. Best mounted high, maybe on the sissy bar for better visibility.The added LED does not require a load equalizer. A switch to LED from stock will require a load equalizer.
Garry 2r's
Rothbury MI
« Reply #4 on: May 22, 2013, 08:52:10 AM »
I have the license plate holder with extra lights and the back off modulator,  Good to have extra lighting.  and just added that super bright led tail light board.
BobB
« Reply #5 on: May 22, 2013, 10:12:26 AM »
I had been using a Kisan Tail Blazer ($70) for several years.  It was on my Tourer when I purchased it.  It has a bright halogen bulb that flashes several time as you apply brakes.  I have replaced it with a LED tail/brake light that also flashes in the same manner.  It is from SuperBrightLEDs.  I also use the LED rings within the turn signals that provide running and brake lights.  Add the LED lights on the mud flap and saddle bag side markers and I have six running lights and three brake lights.  There is a lot of options out there.
Mr.BubblesVRCCDS0008
« Reply #6 on: May 22, 2013, 05:07:27 PM »
Custom Dynamics have all kinds of lighting access. I have the nightrider light on my I/S  it is very bright and eye catching.
Cotton Mouth
VRCC # 28922 Southern Nevada
« Reply #7 on: May 30, 2013, 09:53:09 PM »
Another option, an add on feature.  American made by an American inventor.
https://www.youtube.com/watch?v=lsP-LAkcqhA
I am going to get his Photon Blasters for the front.  Done a lot of research on other forums and haven't heard one bad thing.  http://www.lights.skenedesign.com/
1999 I/S SOLD BUT NOT FORGOTTEN Jan 2015
1998 HD Road King Classic
9Ball
« Reply #8 on: May 31, 2013, 05:11:50 AM »
I've had the Hyperlites since my bike was new in 1999.  Saw another Valkyrie with them at a VOAi ride-in in Montrose, CO and they really grabbed my attention as I was following him.  Good customer service after the sale too when I had a few LEDs burn out, he sent a free replacement no questions asked...just that I return the defective ones so they can do some testing to find out why they might have failed.
http://hyperlites.com/
I have the U32 modulating kit...
http://hyperlites.com/moddf.html
I mounted mine on the license plate bracket in place of the stock red reflectors....already had holes to run the wiring where the reflector stems ran through the bracket.
Good luck...can't have too much lighting on the back of your bike!!
« Last Edit: May 31, 2013, 05:20:48 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
