February 07, 2026, 02:02:19 AM *
Author Topic: Rear wheel & Rotor question  (Read 1454 times)
Dan-bury
Danbury CT
« on: May 28, 2013, 11:36:54 AM »
I have read many (very many) posts from searching, and I am still a bit confused.
I have a Rear Rim with Rotor off a 97 Standard as a spare that I plan to use on a 2000 Interstate. Now if I am reading all the info correctly as long as the rim and rotor are from the same year and model they will fit.
Do I have that right, or does it go deeper than this??
Thank You for any help.
Dan A.
Danbury CT
I have spent most my money on Motorcycles and Women, the rest I just wasted.
F6BANGER
Albuquerque NM
« Reply #1 on: May 28, 2013, 01:36:57 PM »
I believe it will. I have a 97 wheel with a different rotor on my 99 I/S and I use a spacer to make it work.
Dan-bury
Danbury CT
« Reply #2 on: May 28, 2013, 03:30:11 PM »
Thanks for the quick reply
Is the Rotor you are using also from 97, or from your Interstate. And how much of a spacer did you need.
« Reply #3 on: May 28, 2013, 03:37:36 PM »
Dan A.
Danbury CT
you have it right, it will work.
F6BANGER
Albuquerque NM
« Reply #4 on: May 28, 2013, 03:54:50 PM »
Dan,
My 99 I/S has a 97 wheel and the rotor is from a 2001? I think. I took a washer about the size of a silver dollar and a hole the axle will fit through. The washer is about 1/8" thick.
Dan-bury
Danbury CT
« Reply #5 on: May 29, 2013, 05:42:02 AM »
Quote from: Dan-bury on Yesterday at 11:36:54 AM
Dan A.
Danbury CT
Thank You,   I'll be swaping them out in the next few nights.
Dan A.
Danbury CT
Dan-bury
Danbury CT
« Reply #6 on: May 29, 2013, 05:43:19 AM »
Quote from: Dan-bury on Yesterday at 03:30:11 PM
Dan,
Thanks again, I appreciate the info
Dan A.
Danbury CT
Dan-bury
Danbury CT
« Reply #7 on: June 13, 2013, 09:04:24 AM »
For anyone interested, I made the swap.
A Rim & Rotor from a 98 Standard fit onto my 2000 Interstate with no modifications or clearance issues.
There is a big difference between Rotors and although I feel the 2000 I/S Rotor on the 98 Rim would work, it would have pushed the Caliper out far enough to cause the Caliper to hit my Trailer Hitch when the suspension compressed.
Thank You all again for the added info and help.
Dan
« Reply #8 on: June 13, 2013, 04:04:23 PM »
You did it right.  It would not have worked had you used the 2000 rotor
