February 07, 2026, 12:07:25 AM
Thermostat
Topic: Thermostat (Read 1054 times)
BradValk48237
Oak Park, MI
Thermostat
May 29, 2013, 10:49:17 AM »
All,
I have been noticing that the bike seems to be running hotter than it did last year...
I have a Tell Tru Dipstick Thermo, and I know they are not always the most accurate, but it used to run around 200... now its running around 225-230.....
I know the fan is coming on and hear it/feel it on a regular basis.... But I did have an issue a few weeks back when it overheated when I was idling it in the garage while workin on it.... Fluid came out of the overflow tank onto the floor and I think the hot light cam on... can't remember cause when I saw the fluid, I shut it down....
I did just take it for a 400 mile ride up to Timber n Chili's.... one day, 200 up and 200 back and it read around 225-230 most of the way even at 90 plus....( I had a nice red Porsche out front!!!!!) thing was , it was a very cool day, with the air temp around 60's..... should run cooler at speed, I think.
Temp light never came on and it does light on startup.... And the Fan does cycle on and off
SOOOOO "just in case" I just ordered a thermostat and oring......... Can't hurt to have either way.
I know the Tel Tru's can get outta wack, but the bike should run under 200 on that.....
Thoughts? Am I just a worry Wart?
Brad
Re: Thermostat
May 29, 2013, 11:44:49 AM »
Here in AZ, My Tru Tel runs about 210 at 70 MPH. Put your temp guage in a pan of water with a candy thermometer.. Bring them up on a stove and compare. Next, get a thermo tester and read the top hose as it enters the radiator. Watch the fan cycling and note the temps. This should narrow your search.
Anthony
Belgium
Re: Thermostat
June 03, 2013, 05:44:58 AM »
if you have been turning the Tell Tru in (or out) by that big round face, instead of with a 17mm key in that slot underneath,
then you probably turned it out of alignment.
pull it out, and put it in a boiling pot of water on her stove and verify.
turn the dial back to correct.
Anthony
