July 22, 2025, 08:32:18 AM *
Author Topic: Thank You! Daniel Meyer  (Read 1472 times)
Sharkey
GOT CURVES??
VRCCDS0184
« on: July 01, 2009, 04:15:12 PM »
Just wanted to say thanks for taking the time to do the write up on the shifter seal replacement.
http://lifeisaroad.com/valkshiftseal.html
It made the job super easy.
« Last Edit: July 01, 2009, 06:55:07 PM by Sharkey » Logged
Daniel Meyer
The State of confusion.
« Reply #1 on: July 01, 2009, 05:36:17 PM »
I hope you remembered the iced tea. It's important! Cheesy
(you're welcome)
CUAgain,
Daniel Meyer
BradValk48237
Oak Park, MI
« Reply #2 on: November 18, 2010, 05:16:43 PM »
Daniel...
 going to be using this info VERY SOON ( seal is in the way!)... Because my Dragon is bleeding!!!!
Just have one Stooopid question.....
Can you do this WITHOUT draining the oil????
B
« Reply #3 on: November 18, 2010, 05:32:30 PM »
Yes, absolutely.  I did it on MC jack so the bike was vertical and easier to get to the shifter.
Good luck, should take about 15 minutes and that includes the time to get her up on the lift..  Smiley
Hay  Cool
shortleg
maryland
« Reply #4 on: November 18, 2010, 05:33:37 PM »
   I think you will find that your bike is tighter than you think.
 You will loose little if any oil.
           Shortleg[Dave]
Daniel Meyer
« Reply #5 on: November 18, 2010, 05:37:07 PM »
Daniel...
B
Yes. If you have it vertical it won't lose a drop.
CUAgain,
Daniel Meyer
bentwrench
Philadelphia,Pa.
« Reply #6 on: November 18, 2010, 05:41:33 PM »
Place a 4x4x12'' block of wood atop a 6x6x12 place then under the right side crash bar.pull the bike over the top and rest it on the wood.now the shifter is out in the open and the will stay back in the engine.
bw
