November 27, 2025, 01:39:10 AM *
Author Topic: best jetting for cobra pipes  (Read 1413 times)
rocketray
« on: June 04, 2013, 07:20:52 PM »
I am looking at a used interstate with cobra pipes and the carbs need to be redone I believe. I was thinking about putting the proper mods in it then.....it may have been done already     the owner is deceased    is their a decent kit out there?     thanx
CajunRider
Broussard, LA
« Reply #1 on: June 04, 2013, 09:56:00 PM »
Don't waste money on a kit.  It'll run fine with stock jets... just back out the pilots to 2 1/2 turns.  Easy and cheap... including the fact that your gas mileage won't suffer.
If you REALLY want to go up on jets, I would go up 1 size on slow jets, maybe 1 or 2 sizes on high speed jets.  Just remember that you'll lose some gas mileage.
Don't bother with the needle (hence the reason I say not to get a kit)... stock is fine.
I've used these guys... prices aren't the BEST, but shipping is pretty quick.
http://www.jetsrus.com/
Sent from my Apple IIe
6tigo
Member #655
Melbourne Fl
« Reply #2 on: June 05, 2013, 01:43:32 AM »
http://carbjetkits.com/
Four boxes keep us free:
The Soap Box, The Ballot Box, The Jury Box, and The Cartridge Box.
"Any man who thinks he can be happy and prosperous by letting the American Government take care of him; better take a closer look at the American Indian."
Henry Ford
Bocephus
97 Valkyrie
Elizabethton, TN.
« Reply #3 on: June 05, 2013, 06:58:29 AM »
I'm running cobra's with baffles and stock jets. Very happy and no problems. I did wrap baffles with baffle packing for the mellow tone. Sounds great. cooldude
Scottrtho
« Reply #4 on: March 07, 2016, 05:36:44 PM »
Can you tell me more about this baffle packing... where to get and how to use?
Scott
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #5 on: March 08, 2016, 01:34:30 AM »
Baffle packing info please
1999black standard; 2000 black tourer; 1999 red/black interstate
IamGCW
727 hood
« Reply #6 on: March 08, 2016, 03:40:20 AM »
To quiet mine, I got some Stainless Steel scouring pads from Dollar General store.  Stretch and pull them out.  Wrapped the pads around the baffles and used mechanics wire to hold in place (helical wrap).  That keeps the diameter down allowing the baffle to be inserted.  Its been a few years since I did this but I think it was one pad per pipe.
Extracting the baffles can be difficult from the carbon in the exhaust, spraying carb cleaner into the pipe will fix that.  Years later when my intake vacuum caps leaked it was easy to see which cylinder was backfiring, the scouring pad wrap was bunched up at the end of the baffle.  Changed the all the caps and intake O rings, problem solved.
Gil
Gil
« Reply #7 on: March 08, 2016, 03:59:18 AM »
read my post for power
http://www.valkyrieforum.com/bbs/index.php/topic,24312.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,19415.0.html
I used this packing which is the best out there for my viking pipes,
http://www.ebay.com/itm/1-2-20-x38-TECHMAT-MOTORCYCLE-EXHAUST-MUFFLER-PACKING-/131196171454?pt=Race_Car_Parts&hash=item1e8be6b4be&vxp=mtr
« Reply #8 on: March 08, 2016, 04:42:37 AM »
All my bike needed to run perfect with the Cobras was to go to a K&N air filter.
« Reply #9 on: March 08, 2016, 09:04:20 AM »
  cooldude  You might want to consider a 4 degree trigger wheel also. After a desmog, pilot jets at 2 1/2 turns and air filter change, my bike still had a little deceleration pop with cobras. However after I put the new trigger wheel in, the deceleration pop was totally gone. The mid-range performance and was significantly improved and the backrap now is wonderful as you gear down.  Evil
My rides:
