November 25, 2025, 08:36:46 PM *
Author Topic: Engine Cutting out  (Read 855 times)
Rob A
Vancouver, WA
« on: June 09, 2013, 08:40:49 AM »
So yesterday I am cruising down I-5 at about 80 Mph and the engine cuts out for a fraction of a second, just as if I were to toggle the engine kill switch off and on real quick. It has happened twice this year.
I have had it happen once last year and once the year before.
I figured I should check the kill switch and the side stand switch.
Anyone else have this problem?
It's a 99 Interstate with 87K miles on it.
Troubleshooting these intermittent problems is tough.
1999 Interstate
Michvalk
Remus, Mi
« Reply #1 on: June 09, 2013, 09:49:13 AM »
Many have reported the same thing, but, I have never heard of anyone finding the source of the problem. Mine does it about once a year, and after fiddling with all the switches, nothing pops out at me, and it stops doing it for another year. Good luck at finding it cooldude
Mr.BubblesVRCCDS0008
« Reply #2 on: June 09, 2013, 11:06:35 AM »
 My 2000 interstate does it from now and then. I cleaned the contacts in the kill switch and that helped for a while. Now I just cycle the switch a few times every once and a while before turning key on and problem has not reared it"s head again.
Rob A
Vancouver, WA
« Reply #3 on: June 09, 2013, 01:36:31 PM »
Thanks for the reply's.
I will cycle the kill switch more often, I rarely use it.
Most of the time I shut it down with the key or the side stand.
1999 Interstate
Daniel Meyer
The State of confusion.
« Reply #4 on: June 09, 2013, 02:17:16 PM »
Also check the battery cables and ends for tightness, and specifically, the negative cable where it attaches to the bike for corrosion.
CUAgain,
Daniel Meyer
