November 25, 2025, 08:36:43 PM *
Author Topic: Electronic Cruise Control...current options?  (Read 1374 times)
Daniel Meyer
The State of confusion.
« on: June 09, 2013, 02:37:15 PM »
Well, my Audiovox CCS-100 vacuum operated electronic cruise control seems to have bitten the dust.
Can't complain...have run it 170,000 miles now...
Replacement is required. Thinking the modern thing is to ditch the vacuum operated bit...
There are electronic/non-vacuum options...one is the Rosta...link here.
Looks pretty "CCS-100-like"...my concern is that it does not appear to use the tach/coil pulse as a speed sensor, and requires a speed sensor to be installed. I'm wondering if it would accept the tach/pulse on the VSS feed anyway?
Any thoughts? Other options?
CUAgain,
Daniel Meyer
pancho
Bonanza Arkansas
« Reply #1 on: June 09, 2013, 03:30:56 PM »
Good question.... first thing would be to see how their speed sensor operates, is it an opto coupler or what... using the tach pulse directly may or may not work depending on many factors, the impedance of the speed control circuitry is foremost in my thinking. An optoisolatoer circuit could always be designed to use that pulse,, it would be a simple 1 IC circuit,, but the design and fabrication may be a bit time consuming..  I;m with you, I would try to not use their separate sensor if possible,, and it certainly is.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #2 on: June 09, 2013, 04:12:56 PM »
Expensive but check it out
http://www.mccruise.com/collections/honda/products/8
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: June 09, 2013, 05:33:18 PM »
http://www.murphskits.com/catalog/product_info.php?cPath=25&products_id=369\
Murphs
I doesn't use vacuum, $240. 'the unit governs speed based on the input it receives from the bike speed sensor wire' so it might have the same issue.
Fred.
VRCCDS0237
