February 07, 2026, 06:06:44 AM *
Author Topic: Neutral light  (Read 2064 times)
stevenphillips42
« on: June 24, 2013, 05:00:11 AM »
Valk wont start without  the neutral light have checked all the wiring but to no avail. Help please....
« Reply #1 on: June 24, 2013, 05:16:52 AM »
Is the side stand down?  She won't start in gear if the stand is down.  If up, then check the clutch lever for correct movement and/or wear of bushing.  You should hear a slight but distinct "click" when you pull the clutch lever in.
« Reply #2 on: June 24, 2013, 06:54:37 AM »
Most likely:  Clutch lever needs to be replaced.  The pivot hole that the bolt goes through wears into an oval shape so that when you pull in the lever, the tab that pushes the switch doesn't push it in far enough.  Wiggle the end of the lever up and down.  IIRC, a new lever will allow about 1/16" of movement.  The lever that I replaced had more like 1/4" of movement.
Next most likely:  Switch at clutch lever needs fixing/replacing.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: June 24, 2013, 07:03:50 AM »
+1.
If play at the pivot bushing is not the problem check the face of the lever where it contacts the push rod for the clutch master cylinder.  Sometimes this wears a small divot that will prevent the lever from activating the switch.
You should be able to hear the swith "click" when you pull in the lever.  It's also easy to check with a mutlimeter.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Mr.BubblesVRCCDS0008
« Reply #4 on: June 24, 2013, 09:24:38 AM »
Be sure bike is in neutral and bypass the switch pull clutch lever in and try to start. If it starts it is the switch. Just do this for a test do not ride bike in this condition. Sometimes just removing the switch and spraying some contact cleaner will do the trick. You can also us a meter to check switch for operation probably a safer option.
« Reply #5 on: June 24, 2013, 11:53:32 AM »
Unless it's the lever.
stevenphillips42
« Reply #6 on: July 15, 2013, 07:30:40 AM »
How do you bypass the switch?????
« Reply #7 on: July 15, 2013, 07:39:21 AM »
Pull the small wires off the back of it CAREFULLY....they're small, then put a short jumper between them. Or, it's held in place with a single small bolt....remove that and the switch comes off.
Another possibility; have you replaced the grips recently? If the new ones are too thick it prevents the clutch handle from pulling far enough to activate that switch.
« Last Edit: July 15, 2013, 07:42:44 AM by John Schmidt » Logged
donaldcc
Palm Desert, CA
« Reply #8 on: July 15, 2013, 08:40:05 AM »
   I had same problem last fall and it was easy fix for me after advice from most of the above posters.  cooldude  My fix was a simple cleaning of contacts on the switch assembly.  #6 in diagram below.
http://www.valkyrieforum.com/bbs/index.php/topic,48035.msg456490.html#msg456490
Don
stevenphillips42
« Reply #9 on: July 15, 2013, 12:22:40 PM »
Well it isnt the clutch switch.
« Reply #10 on: July 15, 2013, 03:34:59 PM »
Did you check the lever like I suggested?
stevenphillips42
« Reply #11 on: July 16, 2013, 04:57:44 AM »
yepper tested the lever and it is fine....
« Reply #12 on: July 16, 2013, 07:50:28 AM »
By that I assume you put your ear close to the area of the switch and squeezed the handle to see if the switch is being actuated. With normal hearing, you don't have to do that...you can hear it click while sitting on the bike. A sign of the times are such that many riders around 45 yrs. old or younger can't hear it. However, if you squeezed the handle and heard the switch click then we can assume the bushing in the handle pivot is OK. If you removed the small wires and used an ohm meter to test for continuity at the wire attachment posts when squeezing the handle and it showed full needle deflection, then we can assume the switch is OK. I would next use the ohm meter and test each wire from there to the frame.
