February 07, 2026, 04:02:13 AM *
Author Topic: Idle Speads Up when engine gets warm  (Read 1365 times)
Maldog
Woodstock IL
« on: June 26, 2013, 10:54:54 AM »
Hay Guys Im lookin for some guidance on a fast idle issue. My 2001 IS starts fine new battery   oil plugs,a friend and I just checked  the valve settings and they are fine, When the bike  warms up my idle jumps from around 1000 to around 2000 to 2200 Oh No what  to do,,,,, I only have around 12000 miles on my IS. NOW iVE NEVER HAD CARB WORK DONE YET LOL.They have never been sinked or gone through also I have yet to replace the air filter MYBAD Any suggestions and guidance that can save me time and muny  will be greatly appreciated,and thank  in advance   for any help offered You guys hear always  stear me in a positive direction, God Bless
« Last Edit: June 26, 2013, 11:25:23 AM by Maldog » Logged
« Reply #1 on: June 26, 2013, 11:42:40 AM »
The idle will raise as the engine warms up, its normal. Cold start up should be in the 500 rpm range and it'll go up to around 900.  Make sure the throttle cables are working as they should and that there is a slight amount of free-play. Once the engine is warm, set the idle speed correctly [ grey plastic screw between cylinders 1 and 3].
saddlesore
« Reply #2 on: June 26, 2013, 04:01:30 PM »
The idle speed would go up when coming off of the hiway and sitting at the bottom of the ramp.
Check your vaccum hoses for leaks.  If you ake your tank off to change the filter it makes it a lot easier to change the hoses.
There are some short hoses on the intakes with plug in them replace those too.
Replacing those hoses stopped my problem.
DARE TO BE DIFFERENT
« Reply #3 on: June 26, 2013, 04:18:53 PM »
Wait till it warms up then turn it down to 900
pancho
Bonanza Arkansas
« Reply #4 on: June 26, 2013, 04:34:40 PM »
Is this an ongoing problem or has it just suddenly appeared?
magnmm
Davie Florida
« Reply #5 on: June 27, 2013, 05:35:39 AM »
I had that problem with my Interstate. Turns out that the carbs were dirty. Cleaned them and the problem was solved.
Daniel Meyer
The State of confusion.
« Reply #6 on: June 27, 2013, 06:34:07 AM »
That's a classic sign of a vacuum leak.
CUAgain,
Daniel Meyer
Edvalk
Dayton Ohio
« Reply #7 on: June 27, 2013, 06:58:59 AM »
My 98 standard's idle will go up when it's hot outside  90's but only to 1200 . Usually start up is around 500 and then up to 900 when just warmed up. Did intake o-rings and hoses found one cracked. Pops alittle on decel , I think there is a vacuum leak I not finding but other than that it runs great. Ethanol gas Dosen't help .
1998 valkyrie standard , 2007 Suzuki Bandit 1250
Maldog
Woodstock IL
« Reply #8 on: June 28, 2013, 09:45:12 AM »
wow thanks  for all the help guys  im humbled  it seems a lil turn on the idle screw  between #1 and # 3 seems to have corrected the prob,I will be replacing the air filter in the near future so i will take a clost look at those vaccum  lines and may just replace them if they look questionable again thanks  for all the input.
