February 07, 2026, 04:02:23 AM *
Author Topic: Fork oxyidization  (Read 1041 times)
Fudd
MSF RiderCoach
Denham Springs, La.
« on: June 26, 2013, 07:09:41 PM »
I noticed a bit of dissimilar metal oxidization occurring where the stainless steel bands of my windshield wrap around the aluminum fork tube.
I removed the bands and cleaned up oxidization the best that I could, but some permanent damage has been done to the aluminum.
I put some dielectric grease on the tubes where the bands go, and then reassembled everything.
Is there something else that would be better to use to stop, or slow the corrosion?
Save a horse, ride a Valkyrie
« Reply #1 on: June 26, 2013, 11:17:59 PM »
You might try to put clear packing tape under the straps before installing. Steel straps over aluminum tubes in a humid environment require more preventative maintenance.
