February 07, 2026, 04:01:41 AM *
Author Topic: We serviced Squealy's driveshaft and pinion cup today.  (Read 1151 times)
Jabba
VRCCDS0197
Greenwood Indiana
« on: June 29, 2013, 12:25:38 PM »
It was not damaged.  It had about 5400 miles on the service interval from JUST before GOTF.  It did NOT have any final drive oil in there, but there was still grease.
We greased it up again, and put her back together... ready for Inzane.  and our trip around Lake Superior.
Jabba
pancho
Bonanza Arkansas
« Reply #1 on: June 29, 2013, 12:39:21 PM »
I guess we just have to accept the fact with the final drives that some will and some won't............   Grease them up.......     it drives me nuts that the differences between those that will and those that won't have eluded discovery.............  What really surprises me that some of them do.......
Earl in Pensacola
« Reply #2 on: June 29, 2013, 12:45:54 PM »
Just a thought--what if you were to drill the "bleed hole" out just a little bit?  Think it would help?
pancho
Bonanza Arkansas
« Reply #3 on: June 29, 2013, 01:00:27 PM »
It seems the safe bet is to lube them,,, lube them generously!!!!
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #4 on: June 29, 2013, 01:34:36 PM »
I don't think it'd help.  They were not clogged.  and I PROMISE that every one I have done has been SQUEAKY clean.  I take them apart, and clean them in a parts washer, or the sink...  or somewhere.  I remove every trace of grease or oil before I start over the next time.
I seem to have one of each... however, my STD has been ok up till the last time...  Roll Eyes  I still need to tear it apart too... but dang... i can only get to so much so fast...  Undecided Cry
I'll get the STD tore apart again.  When I did the IS it was SLOPPY wet with final drive oil.
Jabba
« Reply #5 on: June 29, 2013, 02:22:25 PM »
THAT should be taken up with your doctor and not the tech board.  crazy2
« Reply #6 on: June 29, 2013, 05:32:45 PM »
Great minds think alike 2funny
signart
Crossville, Tennessee
« Reply #7 on: June 29, 2013, 06:39:46 PM »
Jabba, weren't you experimenting with 1-1/2 ounce overfill with oil lube? Or was that someone else? Would like to hear a report on the results whoever it was.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #8 on: June 29, 2013, 07:40:55 PM »
It was us...
It did not make any oil get into Squealy's pinion cup.
We have not taken mine apart again yet.
Jabba
