February 07, 2026, 04:00:46 AM *
Author Topic: Brain fart--Fuel Valve Question  (Read 1261 times)
rugguy
2000 Valk I/S
Atlanta, GA
« on: June 29, 2013, 01:09:11 PM »
I rebuilt the riveted side of my fuel valve and it's dry as a bone.  But now I can't find the vacuum hose that connects to the vacuum side of the fuel valve. The only hose I see that would be the right size is already connected to the fuel tank vent behind the fuel valve.
I have the airbox/intake pulled and don't see any loose hoses. Can anyone please tell me what the other end of the petcock vacuum hose is attached to. The manual is no help.
« Last Edit: June 29, 2013, 03:09:07 PM by rugguy » Logged
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 29, 2013, 01:20:41 PM »
Left rear cylinder is #6.  Normally there is a vacuum line from the rear side of the intake tube on this cylinder to your fuel valve.  It could actually come from any cylinder, but usually it is on #6.
pancho
Bonanza Arkansas
« Reply #2 on: June 29, 2013, 02:35:27 PM »
Your carbs will get no fuel without that vacuum hose when running a stock petcock.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #3 on: June 29, 2013, 03:21:01 PM »
Thanks......I realized that when I went back out to the bike. The only vacuum hose I can find runs from the back of the #6 carb into a "t". One leg of the "t" is a vent tube that goes down through the frame and hangs loose. The other end I had attached to the small vent nipple at the rear for the fuel tank. Is that correct?
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
Valkpilot
What does the data say?
Corinth, Texas
« Reply #4 on: June 29, 2013, 03:26:07 PM »
That "T" should not have anything attached to it.  It's a vacuum break for the vent line.  The hose that runs from the number 6 carb should go to the vacuum port on the petcock.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #5 on: June 29, 2013, 03:27:26 PM »
Valk Pilot....thanks so much......hope to be riding tomorrow.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
pancho
Bonanza Arkansas
« Reply #6 on: June 29, 2013, 03:31:55 PM »
The line you have in your hand does not go to the petcock.. one end of it should run to the vent line on the fuel tank behind the petcock......  The line that runs to the petcock should be connected to the #6 intake.....  left side furthest to the rear, under the carburetor.
Valkpilot
Corinth, Texas
« Reply #7 on: June 29, 2013, 03:33:39 PM »
He says the line in his hand runs to the number 6 carb.  My assessment was that he connected the petcock vacuum line to the vent "T".
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #8 on: June 29, 2013, 03:38:28 PM »
That is exactly what I did. I had the north end connected to the fuel tank vent. The west end connected to the #6 carb. The south end hung open. I am rerouting as follows. The west end of the "t" will remain open and the hose formerly attached here (from the #6 carb") will be attached to the vacuum line on the petcock.
Thanks again for l the help.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #9 on: June 30, 2013, 02:06:37 PM »
Runs like a scalded dog.....thanks to all.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
pancho
Bonanza Arkansas
« Reply #10 on: June 30, 2013, 02:50:25 PM »
I didn't read his post carefully enough   ........  again   ........    beginning to suspect ADHD
