February 07, 2026, 04:01:40 AM *
Author Topic: Flashing death.  (Read 1214 times)
PhredValk
Edmonton, Alberta, Canada
« on: June 30, 2013, 06:41:11 PM »
Leaving Thunder Bay, ON yesterday, speakers start cutting in and out. Looking down, speedo and tach at zero and the LCD dashboard (Interstate) is rebooting every 3 seconds or so. I pull over and she dies. Key on I have lights and my GPS has power, but no starter. Bump start and it's fine except for the flashing dash. I got to a turn around spot and she just dies. Battery is dead, won't fire.
She's in the shop (long weekend) and I was hoping to find something that may help the mech when he gets in Tuesday morning.  I searched for an hour but didn't come up with any hits. I understand it's probably battery or alternator, but the flashing thing I haven't heard of before.
TIA, Fred.
VRCCDS0237
wiggydotcom
Yorkville, Illinois
« Reply #1 on: June 30, 2013, 07:04:51 PM »
Just a stab in the dark here based on your symptom description....don't overlook the ground connections, including the one from the battery to the chassis. If a ground wire pulls out of the rear wheel connector the bike will display lights similar to emergency flashers when either turn signal direction is selected.
VRCC #10177
VRCCDS #239
« Reply #2 on: June 30, 2013, 07:07:36 PM »
When my alt crapped out on my I/S everything just died. The L C D died and got a couple of good backfires before it died completely. I replaced a battery of unknown age with a new one and a rebuilt alt from M A R S. And insult to injury-the battery checked out good just before it all took a dump on me.  crazy2 RIDE SAFE.
Michvalk
Remus, Mi
« Reply #3 on: June 30, 2013, 07:46:31 PM »
Dash going out is a typical low voltage symptom. I would guess from your description that the alternator gave up the ghost, but, could be a number of things. Hard to tell without throwing the voltmeter on. Did you check the main fuse? Could be something as simple as that cooldude
Mr.BubblesVRCCDS0008
« Reply #4 on: June 30, 2013, 09:23:40 PM »
 My interstate did the same thing. Alt. has died and gone to alt heaven. The goldwing alt. is what I replaced mine with and that was 70,000 miles ago.
eric in md
« Reply #5 on: July 01, 2013, 07:03:01 AM »
alt.. should put in new battery also.  happy motoring .
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #6 on: July 01, 2013, 07:56:37 AM »
That's what mine did when the alt went kaput...  I think you got good advise.
Jabba
