March 10, 2026, 02:58:38 PM *
Author Topic: HELP... 1" - 14 tap  (Read 2140 times)
« on: July 05, 2009, 04:43:01 PM »
Anyone got one they would hook a brother up with ? I boogered the threads on my wifes car tonight tring to removing a broke heater hose adapter ( I guess that's what you call it  Undecided  )  I'll be useing it on a aluminum engine block.If you can help me out let me know I'll pay shipping both ways and buy you supper or a cold one next time we meet.It needs to be ... 1" - 14
junior
new hampshire
« Reply #1 on: July 05, 2009, 04:44:55 PM »
you might want a pipe tap joe a straight thread wont seal
and 1 inch sounds awful big for a heater hose
« Last Edit: July 05, 2009, 04:46:50 PM by junior » Logged
« Reply #2 on: July 05, 2009, 04:47:13 PM »
The replacement part claims it's a 1" - 14 uns thread.
junior
new hampshire
« Reply #3 on: July 05, 2009, 04:48:21 PM »
ok
« Reply #4 on: July 05, 2009, 05:05:39 PM »
The one that came out is plastic the new one is metal . It broke off inside the block and I boogered the threads getting it out.I worked with it about a hour and it just won't start into the threads.
Dino
Fort Worth Texas.
« Reply #5 on: July 05, 2009, 05:09:33 PM »
Just looked, thought I had one,but it's a 1''-8 coarse thread.
So many roads.....They won't ride themselves!
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: July 05, 2009, 05:11:51 PM »
Do you have a Harbor Freight nearby? I got mine there (all smaller than 1" though)
Capt. Morgan
Midlothian, IL , Portage, IN
« Reply #7 on: July 05, 2009, 05:54:22 PM »
Check with some local auto parts.
The Advance Auto by me rents tools, maybe one in your area might do the same.
Capt. Morgan
1999 Valkyrie Interstste
The "Fast Black Type"
« Reply #8 on: July 05, 2009, 06:13:05 PM »
I called Advance and Auto Zone both this evening ( Nope ) . I'll go tomorrow and see if I can buy one somewhere.
« Reply #9 on: July 05, 2009, 06:28:09 PM »
Amazon's got what you want, but I don't see a "one day air"... it would ship Tuesday, and not get
to you for several days after that...
http://www.amazon.com/1-High-Speed-Steel-Plug/dp/B000I6JJDA/ref=sr_1_3?ie=UTF8&s=industrial&qid=1246843576&sr=8-3
Good luck...
FryeVRCCDS0067
Brazil, IN
« Reply #10 on: July 05, 2009, 07:13:22 PM »
Pipe thread would be designated NPT so that is probably a standard bolt thread. I don't have any taps that large at home. I'll check at work tomorrow but I don't think I've got one there either.
A larger industrial maintenance shop would probably have one so if you can think of a bud or neighbor in industrial maintenance they might be able to hook you up.
Scott in Ok
Chief Worker Ant
Oklahoma City, Ok
« Reply #11 on: July 05, 2009, 07:20:54 PM »
http://www.grainger.com/Grainger/wwg/productIndex.shtml?L2=Taper&operator=prodIndexRefinementSearch&originalValue=1-14+tap&L1=Taps%2C
There is a Grainger branch in Knoxville.
Not cheap.
-Scott
« Reply #12 on: July 05, 2009, 07:29:52 PM »
Much appreciated men I'll find out what I can do tomorrow I'm off this coming week so I'll be on the hunt for one ...Again thanks for the response  cooldude
Windjammer
Danny Jones/Villa Park, IL. West Burbs of Chicago
Villa Park, IL
« Reply #13 on: July 05, 2009, 07:33:45 PM »
I am pretty sure I have one in my tool box. I will check in the morning. If I do where do I send it. You can send me a email with your Cell No. and I will let you know.
« Reply #14 on: July 05, 2009, 07:44:40 PM »
Cell # sent...Thank you for looking  cooldude
« Reply #15 on: July 05, 2009, 07:58:07 PM »
Joe just maybe if you grind down the threads on the new piece on the end make them a taper shape you can put a little muscle behind it and get it in. I would say about 3/16 the way up should do the trick. Make the end like cone shape also as a last resort and you tried this and it just about catches then take a hack saw and cut a angled groove in the end just in the taper area and just maybe you can cut and catch the threads this will also somewhat clean up the threads.
« Reply #16 on: July 05, 2009, 08:06:38 PM »
The hole is buried between the A/C and water pump more so the A/C and I sure hope I don't have to pull all that mess off.I'll keep your idea in mind but tapping it out would be my best bet I think.
TomT
Our very first day on the Valk up on the BRP!
Lynchburg, Virginia
« Reply #17 on: July 06, 2009, 09:12:08 AM »
Joe,
I checked my toolbox in the garage and the biggest one I have is a 7/8.  tickedoff I'm off from work until the 12th, but I know I have one at work. If you don't have it fixed by then, let me know and I'll try to get it out of the shop. Security is kinda tight, seeing as I work for a nuclear place and all that.
But in the meantime, should you get one, be sure to put a lot of grease on the tap to catch the little aluminum chips and to keep them from being pushed through into the system. I'm not exactly sure what it is you are working on, engine block or what, but I wouldn't want all those loose chips floating around looking to plug something else up. Just a thought of a veteran 35year machinist. Take free advise for what it is worth! Smiley
Good luck,
Tom Tompkins
Lynchburg, VA
« Reply #18 on: July 06, 2009, 10:31:33 AM »
Thanks Tom I had a friend who had a friend who had a friend who had one  Cool  It's back together now...Thanks everyone  cooldude
« Reply #19 on: July 07, 2009, 04:20:47 PM »
Go to Home Depot in the aisle for irrigation stuff....sprinklers, pvc, fittings, etc.  That's where you should find a tool made for just that problem, it removes broken nipples from irrigation pipe. Just a couple bucks as I recall, and real time saver. It would have worked wonders for you Joe, I've even used it on metal pipe when the pipe isn't rusted in place.
