February 07, 2026, 04:01:39 AM *
Author Topic: question on cutting down windshield  (Read 1284 times)
DesertDragonRider
« on: June 30, 2013, 08:37:09 PM »
I want to cut my windshield down about an inch or more? What blade do I need on a Jigsaw as far as teeth? I think maybe a 24 TPI (Teeth per inch) , is that right?
« Reply #1 on: June 30, 2013, 09:37:40 PM »
Fine tooth and some are cutting thru the blue painters tape after the layout. Double and triple check your measurements and go easy on the cut. You will have to sand off the edges when yer done. Keep in mind-once you cut it off it are GONE.  coolsmiley And keeping the portion being cut still and stable makes for a much smoother cut. Unless you have an old windshield like I did it's damn near impossible to practice first.  Undecided Be careful take your time measure twice cut once.  cooldude Good luck with your project. RIDE SAFE.
ricoman
Sarasota, FL
« Reply #2 on: July 01, 2013, 04:03:52 AM »
many have done it
here's a link that may help
http://www.valkyrieforum.com/bbs/index.php/topic,12905.msg107595.html#msg107595
DesertDragonRider
« Reply #3 on: July 01, 2013, 04:33:13 AM »
Thanks guys! The fine blade is the 24TPI ! Should have kept my old shield to practice on, oh well!
Farther
Quimper Peninsula, WA
« Reply #4 on: July 01, 2013, 07:18:16 AM »
I used a blade marked for use on plastic for straight cuts.  So there may be one available for curved cuts.  Get the curved cut one so you are not fighting the blade wanting to go straight.  The finished cut was way better than I expected and required just a little touch-up with my palm sander and very fine sand paper.
~Farther
« Reply #5 on: July 01, 2013, 09:46:11 AM »
Depending on how much you need to shorten it, a little bracket that pushes the bottom of the shield out/forward can lower it a few inches.
No matter how many times I cut mine, it was still too short !  Grin
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #6 on: July 01, 2013, 10:40:08 AM »
I found that a rotozip worked better for me.  It got the plastic away and kept the whole thing cooler, and didn't make the shield bounce.  When I used a sabre saw... I broke the shield.  When I used a roto-zip, I did not.
YMMV
Jabba
Farther
« Reply #7 on: July 01, 2013, 11:07:41 AM »
  With only an inch to remove you should seriously consider this before cutting the shield.  There was also a post awhile back on how to gently bend the bottom support to accomplish the same.
~Farther
Bocephus
97 Valkyrie
Elizabethton, TN.
« Reply #8 on: July 01, 2013, 04:56:07 PM »
Dremel tool works great. Have cut 2 windshields and no busted ones yet. cooldude
Chiefy
Sarasota, Florida
« Reply #9 on: July 01, 2013, 05:35:34 PM »
I used a fine blade in a sabre saw easy-peasy.
I put several strips of tape on the WS and drove around trying to find exactly where I wanted the cut to be.  I carefully marked it exactly where I wanted it, and it's a little too short now.  Oh well, the old height had the top exactly in the middle of my vision, like a pair of bifocals, so this is better.
After I cut it, I picked up some helmet buffeting.  I was going to buy a set of Baker Wings anyway.  They tuned out the buffeting, so all is well.
Raider
Three bikes
« Reply #10 on: July 01, 2013, 07:59:53 PM »
Seems like a fine blade band saw would be best.  You've got to have someone close by with a band saw.  If not, it's a great excuse to get one!
ricoman
Sarasota, FL
« Reply #11 on: July 02, 2013, 03:59:52 AM »
Using a bandsaw would mean taking the windshield off the bike. That may be OK for an IS.
That is not the best way to cut it down for a Std. or Tourer. Horsing the chunk of plastic around the bandsaw blade would be awkward at best and maybe a bit risky.
I'm thinking using a Dremel like Bocephus did would do really well.
« Last Edit: July 02, 2013, 04:01:45 AM by ricoman » Logged
shortleg
maryland
« Reply #12 on: July 02, 2013, 04:45:03 AM »
  What kind of blade did you use on the roto-zip.
       Shortleg[Dave]
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #13 on: July 02, 2013, 05:24:01 AM »
       Shortleg[Dave]
I don't remember... but it would cut the plastic and throw it out of the way so it didn't get hot and melt things.  It worked really well.  It MUST have been just a standard cutting bit.  All I can remember buying for it are those and sheetrock bits.   Cheesy
Jabba
