November 25, 2025, 08:47:56 PM *
Author Topic: How warm does your final drive get?  (Read 1585 times)
Bugslayer
Lubbock, Texas
« on: July 01, 2013, 07:14:11 AM »
I've owned my '97 Tourer for fourteen years, and I can't remember feeling the final drive during/after a ride.... until a few days ago. The air temp that day was in the high 90's and we had spent the afternoon at highway speeds. The pumpkin was very warm to the touch. That sound about right?
(Within the past month, I changed the final drive oil.. Mobil 1 Synthetic Gear Lube 75W-90)
Regis
Columbus, In.
« Reply #1 on: July 01, 2013, 02:44:22 PM »
being warm to fairly hot to the touch is not out of line . The entire driveline will pass heat from part to part , its all steel . Even the rear wheel will be warm to a slight degree .
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #2 on: July 01, 2013, 03:32:35 PM »
Bugslayer, I've got a IR Thermometer & I've used it to check the temp on the pumpkin before...I can't remember the readings but next time I go for a good ride I'll check it...I just remember thinking that it got hot...I use Mobil 1 Synthetic Gear Lube 75W-90 too....
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
Daniel Meyer
The State of confusion.
« Reply #3 on: July 01, 2013, 03:45:01 PM »
Too hot to hold your hand on, not hot enough to do burn damage if you touch it briefly.
CUAgain,
Daniel Meyer
Bugslayer
Lubbock, Texas
« Reply #4 on: July 01, 2013, 04:32:59 PM »
From the replies, it sounds like all is good. When I checked it, it was close to (if not over) 100* outside.... and we had gone probably close to 100 miles. I could hold my hand on it for two or three seconds before I had to move it.
Thanks !
Valkpilot
What does the data say?
Corinth, Texas
« Reply #5 on: July 01, 2013, 04:41:03 PM »
Daniel, I'm thinking it was something like 290 degrees. I checked it right after I did my last final drive service...wish I had checked it before...
What Daniel descibed is in the range of 150 F.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
lee
Northeast Tennessee
« Reply #6 on: July 01, 2013, 05:02:22 PM »
I have checked mine several times with a IR Temp.  Always around 180.
Time is not what is taken but what remains.
C. Drewry
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #7 on: July 01, 2013, 09:14:52 PM »
Just got home tonight & checked mine...the ambient temperature outside was 70 degrees & the drive shaft housing where it bolts to the pumpkin was the hottest spot 135 degrees.
GEORGE ELIOT
Bugslayer
Lubbock, Texas
« Reply #8 on: July 02, 2013, 02:23:22 AM »
Thanks for the info!
We have a lazer thermometer at work. I'll see if I can get my hands on it.
9Ball
« Reply #9 on: July 02, 2013, 10:12:52 AM »
Since I switched to the Mobil 1 synthetic 75w90 the pumpkin is noticeably cooler to the touch.  I've read reports of up to 30 degrees cooler than non-synthetic 80W.
I use the Mobil1 in both my wife's VTX and my Triumph Rocket 3...good stuff.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #10 on: July 03, 2013, 06:10:04 PM »
Did another test today...rode 45 minutes between about 70 mph..outside temp 85 degrees...Stop a gas station & checked temp...153 at its hottest point where the final drive housing connects to the pumpkin...
GEORGE ELIOT
Bugslayer
Lubbock, Texas
« Reply #11 on: July 03, 2013, 08:32:00 PM »
Cool... Thanks for the info.
I'm planning on getting out Saturday after work. If I can  borrow the lazer thermometer from work, I'll check mine.
