February 07, 2026, 06:07:22 AM *
Author Topic: Just trailered her home....Found the Problem  (Read 3351 times)
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« on: July 05, 2013, 08:18:14 PM »
kind of messed up my weekend. I was pulling out of a gas station about 60 miles from home and was accelerating normally and about third gear, just like turning a light switch she started a loud clicking like a baseball cards in the spokes. Pulled her off the road and she was running fine but clicking at a rate proportionate to the RPM's. Turned around and went back to the gas station. Sound seemed to be under the right valve cover. Went home and got a trailer and a  Harley buddy to ride along (so embarrassing). She started up fine, still clicking, and I pulled her up on the trailer. Anybody got any suggestions what it might be?
2000 Interstate
38,000 miles
« Last Edit: July 10, 2013, 08:13:51 PM by mirion » Logged
jimmytee
Elizabethtown,KY
« Reply #1 on: July 06, 2013, 03:53:35 AM »
That stinks. I'm assuming that since you stated that the noise seems to be proportional to the RPMs ,that the noise is present when in neutral and at a stand still. I don't have a magic answer , but it sounds like possibly a vacuum line or exhaust leak. Check your vacuum lines for cracks or breaks and your exhaust header bolts/gaskets. Also, thoughts of something amiss with one of the spark plugs,possibly loose maybe?  The other ideas(clutch,valves etc... )that come to mind may be more serious, but your mileage wouldn't immediately seem to indicate those kind of concerns. Of course if the noise you speak of happens while only in motion, then we'd be looking at the driveline. cooldude crazy2
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #2 on: July 06, 2013, 05:37:24 AM »
I don't know how the water pump is designed on  these  bikes but mine clicked in my car when it went out. It was the bearings in the pump.
« Last Edit: July 06, 2013, 06:01:25 AM by Mildew » Logged
jimmytee
Elizabethtown,KY
« Reply #3 on: July 06, 2013, 05:44:04 AM »
I don't know how the water pump is designed on threes theses bikes but mine clicked in my car when it went out. It was the bearings in the pump.
cooldude yes water pump was on my list too, but with only 38,000 miles, it just seems unlikely.
trout dude
Hammond Louisiana
« Reply #4 on: July 06, 2013, 06:32:28 AM »
They also have a air tube under the head if the bike was not desmogged. And if it was i'm under the impression that that hole would have to be plugged.
   Trout Dude
Pete
« Reply #5 on: July 06, 2013, 06:45:33 AM »
If the noise is really coming from the valve cover?
It could be a carbon up valve that is stuck partially open.
Or an adjuster that has loosened up.
Remove the valve cover and check for a very loose appearing rocker arm.
Some early goldwings did have problems with carbon on the valve stems.
Former BMW Guy
Aut viam inveniam aut faciam.
Apple Valley, MN
« Reply #6 on: July 06, 2013, 06:56:13 AM »
+1   cooldude
Yup....that would be the first thing I'd do.
JP
Motorcycling is not, of itself, inherently dangerous.
It is however, extremely unforgiving of: inattention, ignorance, incompetence or stupidity.
mirion
1997 Std - 2000 IS
« Reply #7 on: July 06, 2013, 12:26:08 PM »
Its still on the trailer......
It was desmogged 15,000 miles ago. I did it using Redeye vacuum plugs, tight fitting soft plugs and soldered shut the two tube fittings and bolted them back on.
I had the pipes off for spring cleaning 350 miles ago and did not change the exhaust gaskets. I do that every third time, I know most do it every time but it has been working for me and I take my pipes off both bikes every year, its the only way to keep them clean in the hard to get to places, especially the Cobras. I don't see how it would be possible for the exhaust to suddenly start leaking, where would the gasket go? All of the exhaust nuts are tight, first thing I checked out on the road yesterday.
I removed the valve cover today and everything seems tight under there and the valve clearance checks out.
Its runs good, I am just not positive it is a mechanical click, now going to investigate vacuum and exhaust leaks, keep you posted.
Kymbo
South Australia
« Reply #8 on: July 06, 2013, 01:50:09 PM »
use a flexible plastic tube ,hold one end to your ear and the other to the area on the bike that is making the noise and move it around until you hear where the noise is coming from .Tube acts like a stethoscope makes it easier to locate a noise like that
Mr.BubblesVRCCDS0008
« Reply #9 on: July 06, 2013, 04:11:50 PM »
On one I desmogged I used some vacuum tubing caps to plug the large tubing that went to the pairvalves and one of them blew off made a lot of noise and changed sounds with rpms didn't hurt preformance rode it home  and fixed it right.
« Reply #10 on: July 06, 2013, 04:34:31 PM »
Good luck! I'm going to wait and see what you find. That sound would certainly concern me.
My rides:
Tropic traveler
Silver Springs, Florida
« Reply #11 on: July 06, 2013, 05:17:37 PM »
Something under the timing cover?
Not dropping a cylinder kinda confirms the all OK under the valve cover.
'13 F6B red for Kim
stude31
Topeka,ks
« Reply #12 on: July 06, 2013, 06:38:07 PM »
Yes, I would check the valves on both sides (already half done if you do one side), and then I would do a compression check on all six cylinders.
This is by no means an insult to your intelligence but have you checked the oil?
Stude31
mirion
1997 Std - 2000 IS
« Reply #13 on: July 07, 2013, 03:21:57 PM »
Stude31
Yes, Oil was the first thing I checked and the exhaust nuts second. Like you say I might as well check under the other valve cover,  thanks.
« Reply #14 on: July 08, 2013, 10:10:02 AM »
I would like to see a bigger pic of 'your bike' under your post. It'll help me think.  crazy2
Farther
Quimper Peninsula, WA
« Reply #15 on: July 08, 2013, 10:11:09 AM »
You can go to jail for what you are thinking!   police
~Farther
« Reply #16 on: July 08, 2013, 10:39:16 AM »
Me!???  Grin
Oklahoma_Valk
Central OK
« Reply #17 on: July 10, 2013, 01:58:46 PM »
You're welcome!
Let those who ride decide.
flcjr
Manhattan,Montana
« Reply #18 on: July 10, 2013, 03:07:35 PM »
Are you sure it's engine noise?? does it do it in neutral??  pinion cup and drive shaft stripped ?
« Reply #19 on: July 10, 2013, 03:34:18 PM »
You're welcome!
« Reply #20 on: July 10, 2013, 06:07:33 PM »
Fudgie behave yourself, that's somebody's daughter.  Evil 2funny crazy2
Beautiful bike and beautiful girl.
My rides:
mirion
1997 Std - 2000 IS
« Reply #21 on: July 10, 2013, 08:11:47 PM »
Got to the bottom of it, pretty simple actually. A vacuum leak. It was the front right soft plug from the desmog 3 years ago had blown out. Just put in a new one but this time I staked the hole, something I did last year when I desmogged my 97. They were 9/16 plugs which is actually .011" bigger than the 14mm plug suggested for that port so it should have been a tight fit. It sure sounded mechanical at first but it was a simple fix.
The Problem
After
Took her around the thumb of Michigan yesterday and she is running fine.
And just for you Fudgie, my 97 from another angle.......
« Reply #22 on: July 11, 2013, 05:52:34 AM »
And just for you Fudgie, my 97 from another angle.......[/size][/size]
I like her much better!  cooldude
« Reply #23 on: July 11, 2013, 08:28:15 AM »
Yeah, looks legal!  Hoser   cooldude
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #24 on: July 11, 2013, 09:24:19 AM »
Does your headlight stick out like that with those girls sitting on it?  Shocked
« Reply #25 on: July 11, 2013, 11:58:21 AM »
Mine wood.   Cool
« Reply #26 on: July 11, 2013, 01:29:29 PM »
There's a headlight in those pics ? Oh Yeah ! Who knew !
« Reply #27 on: July 11, 2013, 02:33:26 PM »
lol you guys are funny!
I really hope my bike gets dirty on the way to Sturgis. I see a $40 bike wash in my future.  crazy2
Valkpilot
What does the data say?
Corinth, Texas
« Reply #28 on: July 11, 2013, 04:00:57 PM »
Don't you mean a $5 bike wash and $35 in "incentive bonuses?"
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #29 on: July 11, 2013, 04:03:03 PM »
2funny yup!  cooldude
jimmytee
Elizabethtown,KY
« Reply #30 on: July 12, 2013, 10:45:40 AM »
Oh I wish I was that seat.... Grin
