February 07, 2026, 06:06:47 AM *
Author Topic: crankcase filter?  (Read 1243 times)
CMA_Carl
« on: July 07, 2013, 07:41:23 PM »
I de-smoged years ago, but i have the tank off right now and am noticing that I did not get rid of the crap crankcase filter and box that in runs to. What size filter is that and where do i get one?
God bless y'all real good!
Carl
Anthony
Belgium
« Reply #1 on: July 08, 2013, 12:42:26 AM »
if you are looking to replace that OEM breather filter with a small chrome one:
i used a K&N 62-1360 with a 3/4" connection, it plugs just right over that tube where the rubber hose used to be.
Anthony
« Reply #2 on: July 08, 2013, 09:58:27 AM »
Where is this at? I dont remember doing it on my desmog.  ???
Farther
Quimper Peninsula, WA
« Reply #3 on: July 08, 2013, 10:13:01 AM »
Carl
Do you have a California spec Valkyrie?
~Farther
CMA_Carl
« Reply #4 on: July 08, 2013, 06:54:44 PM »
No not California spec... Just a normal 1999 Standard Valkyrie. There's a black drain that comes out of the bottom of air box. It feeds into a black box behind the ignition and a 3/4" hose comes up from the transmission into the same box. Then out of there to the bottom of bike. it's capped and when you drain it a few times a year... nasty gunk drains out.
thanks for the info about the K&N.
« Reply #5 on: July 08, 2013, 07:17:21 PM »
I dont run a filter after removing that separator, just a u shaped rubber hose. It runs to just about a inch down between the engine and trans. I didn't have much luck with the filter you want to use, not to mention I could smell the crankcase fumes at times. So by having it where I put it stuck at a light you dont smell anything.
